JMB RetrofitsAH Fabrications
    jamie226bhp's Avatar
    Aug 2009
    464
    Diff oil seals replacement a4 quattro
    i've noticed my seals are leaking how hard are these to replace and what sort or time scales and cost to do the job
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    I wouldn't say there a pain drop the driveshaft, two bolts in the coupler to create a lock with a pry bar then undo the centre bolt remove coupler, pry out old seal, gently tap the new seal in build it up, fresh oil in jobs a good'un !!
    Aug 2009
    464
    How much would you say it would cost me to
    Get someone to do it
    2000 A4 1.8 tqs scroll sp51, ths decat, milltek cat back with rs4 backbox, remap
    Aug 2010
    3,136
    It depends were you take it you may get a greedy b*****d or someone who just wants a bit of quick cash !! Get a few prices then go for the best one you feel comfortable doing the job for you !
    Aug 2009
    464
    How long time wise did it take you as that will give me some indication because of the hourly rate
    Aug 2010
    3,136
    I haven't done them on mine yet but looking at it I'd say for both sides around 1-1.5 hours roughly I'd say.
