Volks AutosChris Nott
    Jun 2011
    bristol
    63
    boost on 96 20v turbo aeb
    hi im new to my audi a4 its got a boost guage i runs about 7psi on full boost then drops to about 4.5/5psi is this right
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,883
    Yes That's right for 150hp on stock ecu as I've just learned as mine was running that on the 180hp and it should be 12psi so am in the process of eliminating my boost leak
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    Jun 2011
    bristol
    63
    ok thats good i seen yours thought i would find out just got my a4 yesterday hant had a turbo before lol does a boost controller do much
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    my 150bhp APU engine is showing 10-11psi peak and holding 7-8psi(ish)... bit odd
    Currently rolling in a SKODA!!!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,941
    APU runs a different ECU and different boost control though, so its possible that explains the larger peak.
    I guess it also depends what the OP means by "drops to 5psi". I'd expect it to tail off near the top end of the rev range, but it should hold 7-8psi thru most of the revs.
    TD5 Land Rover Defender build
