EM TuningAH Fabrications
    Jun 2011
    54
    b5 will springs from a 1.8t fit my tdi se??
    will these springs fit
    they are lowering springs advertised as - audi a4 1.8 turbo (b5) jamex lowering springs
    will these fit my 110 tdi se ??
    thanks dan
    2,178
    are they from the same body shape of car saloon or estate.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    yes they'll fit fine.
    Exact amount of lowering might change a little, but then cheap springs are typically sold as covering a wide range of engines anyway, and typically the 4 cylinder engines are all lumped togehter.
    TD5 Land Rover Defender build
    Jun 2011
    54
    ye mines a 110 tdi se 1998 saloon , right its on std shocks and springs at the front but it has uprated shocks and springs -40mm at the rear do u think if i buy just a spring kit say 40mm ,i can get my ride height correct?? or will i have to go to std shocks on rear also thanks dan
