Monster MotorsportVolks Autos
Results 1 to 8 of 8
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    REAR AXLE FRONT BUSHES
    I noticed today that the front bushes on the rear axle aren't looking to healthy.Is it worth putting poly bushes in or just new oem ones?
    thanks in advance
    tony
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,378
    New OEM ones will make a huge difference, and cost about £7 each.
    TD5 Land Rover Defender build
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    thanks for that.
    Are they difficult to fit?
    tony
    May 2010
    Bedford
    2,877
    More like 27 plus vat for genuine..each
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    "Stick a V8 in it!"
    15,378
    I baught mine from AllGermanParts.
    A lot of the stuff is real Audi parts and someones just ground off the Audi rings and removed the Audi tax along with it!
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    are they hard to fit?
    thanks
    tony
    May 2010
    Bedford
    2,877
    When they do them at work on other models which have similar they end up ripping the rubber out and then using an air chisel to get the casing out. Then the new ones slip in pretty much. Can be done on a drive its just not the easiest job to do. Bit of brute force is needed to get them out and various cutting is required. Also heard freezing the new bush makes it easier to get in.
    2,169
