REAR AXLE FRONT BUSHES
tonya4
TDi Powerrrr
North Devon
I noticed today that the front bushes on the rear axle aren't looking to healthy.Is it worth putting poly bushes in or just new oem ones?
thanks in advance
tony
I baught mine from AllGermanParts.
A lot of the stuff is real Audi parts and someones just ground off the Audi rings and removed the Audi tax along with it!
When they do them at work on other models which have similar they end up ripping the rubber out and then using an air chisel to get the casing out. Then the new ones slip in pretty much. Can be done on a drive its just not the easiest job to do. Bit of brute force is needed to get them out and various cutting is required. Also heard freezing the new bush makes it easier to get in.
977
889
700
