Volks AutosAH Fabrications
Results 1 to 9 of 9
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Help needed with ETKA !
    trying to install and im getting this message - this system is no fatclient or etmaster 2000 server. the installation will be aborted !!!
    anyone help !!
    Move if im in the wrong section admin !!
    2,178
    What OS are you trying to install etka on, also what version of etka o you have
    Aug 2010
    3,138
    OS ?? Etka7 just as I choose the language it comes up with the message that I previously posted !
    2,178
    Yes OS windows 7, vista or XP. Also 32bit or 64bit windows.
    If it is etka 7.0 then I don't think it will work with windows 7 or vista, you will need 7.1 or later (from what I can remember)
    Aug 2010
    3,138
    I have vista that's all I no lol
    2,178
    Don't think 7.0 will work With vista did a quick google and it looks like you need 7.1 or later.
    Aug 2010
    3,138
    Kk I'll try that tomorrow if I can get it.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    I run ETKA7 on Windows 7 using Oracle VirtualBox with XP installed inside.
    TD5 Land Rover Defender build
    2,178
    Also have a simlar setup, main OS is Home server 2011 have VMware Workstation installed running XP VM with etka 7.3 & elsawin 3.9
