Badger5JMB Retrofits
    jamie226bhp's Avatar
    Aug 2009
    464
    Boost map sensor fitting
    Is it possible to fit a boost sensor to my 1.8tqs ajl instead of just using the maf to control boost or is it un realistic because of cost or work involved
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,651
    New harness and new ecu. (from a later engine, APU/AWT iirc), Aragorn knows about this i think, no doubt he'll be around some time soon.
    Currently rolling in a SKODA!!!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,391
    The ECU's with the boost sensor are all electronic throttle, so you'd also need to change the throttle body, add the pedal sensor, find suitable MAF and injectors etc. So not a streight swap, but looks to be relatively plug and play so long as you have a 2000MY car.
    I've got myself an APU ECU and loom here, as i fancy converting the Shed to DBW as a proof of concept, i also fancy adding wideband and a ME7.5 ECU as well.
    TD5 Land Rover Defender build
    Aug 2009
    464
    I'll wait for u to work out the details then I think and see what the result is
