EM TuningBadger5
    May 2011
    HELP INSTRUMENT CLUSTER
    baught myself a 1999 audi a4 quattro and the lcd display on the clocks keeps flashing off and on and beeping everytime whilst driving and whist stood still..... any ideas? ......
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,116
    Could be oil warning or washer fluid level or a fault on the abs !
    2,153
    Do you have access to VDCS/vag-com? Where are you based as may users on here have vdcs. Are there any other warning signs or other issues with the car?
