AH FabricationsChris Nott
Results 1 to 10 of 10
Thread: What Turbo?
    Jun 2011
    Wakefield
    What Turbo?
    Hi all,
    I have a '96 1.8T with the AEB engine, looking to fit a larger turbo at some point, can anyone point me in the right direction?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    Your first choice has to be a power target. Everything else depends on that figure.
    TD5 Land Rover Defender build
    Jun 2011
    Wakefield
    Not planning on mega BHP in all honesty, the car has just done 200k but there is a tiny crack on the turbine housing.
    I'd rather uprate than straight replace. So more power... I'd probably be looking down the avenue of:
    Turbo
    Front Mount Intercooler
    Enclosed air filter (Car has been running a 57i since before I bought it)
    De-cat
    Re-map or mappable system.
    Obviously I think I'd have to uprate my clutch and brakes at the same time...
    Also need to find some coilovers in due course too!
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,883
    If your not going for any power goals And upgrading you could go with a genuine Borg warner bolt on K04-015 (around £700 and not a eBay shanghai special at around £300) good for 210bhp or go scroll or Frankenturbo they are are good for 240-300bhp depending on compressor spec (around £600-£800) franken is the better deal as you get the exhaust manifold and diverter or 3" maf !
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    "Stick a V8 in it!"
    14,949
    Yeh the frankenturbo is a good buy i think.
    The turbine housing on every single K03 turbo in existence is probably cracked, it usually doesnt affect them at all, why do you think yours needs replaced?
    Jan 2011
    54
    Im going t3 with external wastegate and screamer pipe just to be different
    Aug 2010
    2,883
    Screamer pipe on a A4 I likey lol
    Jan 2011
    54
    thanks lol
    Oct 2009
    Melb, Aust
    48
    You may have problems tuning with the ecu on a 96?
    96 A4 1.8TQ
    K03-073, 1 BAR CHIP, PORT N POLISH HEAD, SUPERTECH VALVES, JE PISTONS, SCAT RODS, FIDANZA FW, SOUTHBEND STG3, CUSTOM AIR BOX, 034 HIFLOW MANIFOLD, 034 PHENOLIC SPACER & FIBER GLASS INSULATED INLET MANIFOLD.
    'TO COME'
    2.5 IN EXHAUST, BILSTEIN H&R.
    "Stick a V8 in it!"
    14,949
    Yeh, probably best swapping it for a later harness and ECU.
