    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    RS4 bumpers, whats the going rate?
    As per the title, whats the going rate/ accepted rate for RS4 front and rear bumpers? What should i be looking to pay?
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Good con 2nd hand FRONT £3-400 ea REAR £200
    Or look into ones with slight damage, rare but do come up, usually half the above stated prices and will need work anyway if fitting onto standard body cars.
    Project RS28 build
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Quote Originally Posted by Foxmeister View Post
    thanks for that, just bought the rear off Grizz for £180 needing a bit of work and the front on ebay for £90. The front has major cracks although the seller reckons its sorted with fibreglass Had my mate price plastic welding and a respray for £150 all in so maybe a bit of a bargain???
    Jun 2010
    Coventry/Warwickshire
    2,074
    Fix the cracks with a solder iron and cable ties (plastic welding )
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Yes mate, sounds a good rate.
    My front had slight damage and still cost me £150, had it knocked down from £225!!!!!!!!
    Was the front from Ebay??? If so, a bit of strpping behind the break, then either plastic weld or even a good flexible filler will sort it. Mind do it after trial fitting to the car thou, as it will flex when fitting to a standard width body.
    What car is it going on??? Whats the plan, get a project thread up if its going thru some changes, need to keep these B5's alive!!!! lol
    Project RS28 build
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    Quote Originally Posted by Lingy. View Post
    does that method actually work? How exactly do you do it?
