Monster MotorsportChris Nott
Results 1 to 17 of 17
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    1.8T Remappable ECU'S
    At what year did the B5 ECU become remappable? As i have read on here somewhere that some have to be chipped or switched out to a later ECU??
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    Effectively none of them are flashable, they all have to be chipped.
    The early ones are extremely difficult/impossible to find the physical rom chip they require, as its long discontinued and isnt rewritable. The later ECU's use a much more common rom.
    A good tuner doing a custom map on one of these ECU's would use an Emulator in place of the rom, while he got the map nailed down, then he would burn the virtual rom to a real chip and fit it.
    TD5 Land Rover Defender build
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    thanks for that, so what would be considered an early one? which years? A good tuner being someone like MRC?
    "Stick a V8 in it!"
    15,324
    They changed over around 1997 i think.
    You can tell just by looking at the ECU. The early ones are really chunky square oldskool looking things, and have 5 small individual plugs. The later ones are slimmer and rounded off, and have two large plugs.
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    hmmm, ive got an early 97 on a P. I'll have to take a look when i get the car back here on Friday. If it is the early one am i knackered in the way of tuning or can i swap it out for a newer one relatively easily?
    "Stick a V8 in it!"
    15,324
    You can swap the later harness and ECU in without too much problem, infact i have one here if your interested :P
    May 2010
    Bedford
    2,877
    Yay i have a later one on a 98 lol.
    If you`re chassis number is up to 8DW100 then you have an early one, if its over that then its a late ECU
    Saying that looking at a 97 if its 8DV onwards then it goes up to 99..
    hhm chassis number is needed to work it out properly.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    I could be when i have had a look to see what i have there on friday. How much are you looking for?
    Quote Originally Posted by Jason.s View Post
    I'll get the chassis number on friday
    "Stick a V8 in it!"
    15,324
    I'd like £50 for the ECU and harness.
    LeeT's Avatar
    Apr 2009
    Hampshire
    427
    fair price, i'll give you a shout when ive had a look
    Oct 2009
    190
    Kind of on the same subject Ive got a chipped ecu to swap over for my standard one but it run like s**t after setting it all up. Check both of them the only difference is the last 2numbers and very last letter. Would I need to get hold of the chipped ecu harness to?
    Oct 2009
    190
    14 hour shift my grammar is shocking. Haha
    "Stick a V8 in it!"
    15,324
    It should run fine, unless you've fitted the wrong MAF or something.
    Theres a few different MAF's depending on the exact ECU you've got.
    Oct 2009
    190
    Vagcom said something about 02 sensor and MAF. But runs fine with standard ecu. For the short time it was fitted the revs were really lumpy and throwing out black smoke.
    boost-addict's Avatar
    Aug 2011
    977
    it could have a mafless map. but as its not set up right its overfueling
    "Stick a V8 in it!"
    15,324
    Cant do mafless on DBC cars, they have no boost sensor and narrowband lambda.
    Oct 2009
    190
    It's being sorted now, the ecu that was sent had a different bosch number. A new one is being sent over now that identical to mine.
