JMB RetrofitsBadger5
    May 2010
    netherley
    10
    s4 air bag light.
    Hi people,
    Im having some bother with my b5 s4 air bag light well its been reset and after a few miles its back on why?
    I have changed the male and female connectors under the drivers seat but no diffrence after a reset so was thinking can i delete the connectors and just join the wires?
    Or advice would be perfect....
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    You need to find out WHY its on, rather than just resetting it.
    A proper vagcom scan will tell you.
    If its the drivers seat airbag then as you've suggested you can solder the wires together.
    TD5 Land Rover Defender build
    Jan 2011
    Aberdeenshire
    646
    I'm having a similar problem, and Vag-Com is giving me the 65535 (Controller Malfunction) code, and when connected , the Module reports the part number as starting with 8@0 as opposed to 8D0! It then reports an error when you clear the DTC. The e-bay code clearer works, but if the outside temp is low, it comes back on - and in Aberdeenshire, it is ALWAYS low!
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    "Stick a V8 in it!"
    15,385
    sounds like new controller time in that case
