Sky InsuranceAH Fabrications
Results 1 to 31 of 31
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    Whispy after cat removal!!
    Hello gents! Had both the cats chopped off my 30v v6. At first the centre box was off too and just running a miltek back box (full milltek system from cats back). It was a bit too noisy so put the centre box back on. Now, when its under load it sounds a bit tinny/whispy! Does anyone know why this is? Is it because now the cats are gone the gasses are passing through quicker, and hitting the "Y" section on the milltek end? Short of putting the cats back on (which is not going to happen untill MOT time) does anyone have or reccomend a cure for this? Anyones input would/will be great!
    Ollie....
    !!BINGO BONGO!!
    Oct 2009
    188
    Just a guess, but maybe not enough baffle in the system now.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    All you can really do is try more and/or different silencers.
    A lot of NA engines go the same way when decatted with a free flowing exhaust, which is why most of the chavvy kids cold hatches sound the way they do.
    Its probably related to the design of the exhaust manifolds. Very short primarys and typically poor collectors merging into a single pipe far too early. My brother had a 1.2 nova on a big-bore exhaust back in the day which sounded horrible on its standard manifold, but once equipped with a nice tubular 4branch with long runners sounded so tasty he often got folk asking if it was equipped with an XE.
    TD5 Land Rover Defender build
    Jun 2011
    This is a very common problem that everyone moans about with all cars when they take the cats off. Just putting an idea out there, maybe some could invent some kind of baffling mesh that could be added to cat replacement pipe or somthing like that as the problem is purely down to increase in free flowing gases.
    Suppose back in the early nighties when everyone fitted scorpians it was always going to sound better because there were no cats to remove so we didnt have a cat'ed sound to begin with.
    My wifes 1ltr corsa had a new back box which sounded rank compared with the old one, turned the originals were double baffled and the after markets were single, so maybe like aragorn said try other silences, preferrably one which is known for baffling
    "Stick a V8 in it!"
    14,900
    Its not like your now flowing 20% more air thru the exhaust, the changes in flow are tiny, probably in the region of 5%, and this really wont change the sound by much.
    The Problem is simply that the cats themselves act like a silencer, and that due to their removal you have less silencing. IE you can now hear the rubbish sound coming from the exhaust manifolds.
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    Its not coming from the exhaust manifolds. The whispiness/tinnyness Is originating from the Y split where it turns into a single pipe. We had the car up and its very clearly coming from there. True the cats were deadening some sound. The only thing I csn think of is to get rid of that Y split with a twin exit, or put a larger silencer on but not sure that will work as its after the Y split.....Oh well! Lol!
    !!BINGO BONGO!!
    "Stick a V8 in it!"
    14,900
    All the noise comes from the manifolds
    Perhaps redesigning the Y so it offers a smoother transition might help? Does it look well made?
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    Yeah its a Milltek! Oh well bugger it......Its not the manifolds. Mate, its not the manifold. Aragorn, guess what, ITS NOT COMING FROM THE MANIFOLDS. THE SOUND IS NOT COMING FROM THERE. LOL
    !!BINGO BONGO!!
    "Stick a V8 in it!"
    14,900
    All the sound has to come from the manifolds
    Where else can it come from? It cant get into the exhaust from outside can it!
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    Yes, agreed.....Mate I'm on about where the tinny/whispiness is coming from, not where ALL zorst gasses come from buddy! lol!
    !!BINGO BONGO!!
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    Back onto this, If I had a system built (now very tempted) that ran two straight pipes INSTEAD of Y section where the two join does anyone reckon this would get rid of the tinny/whispy sound now it has been decatted. It sounds like, when standing underneath the car, that the gases are hitting the join in the Y section where both the pipes become one and thats where its coming from (yes aragorn,i know all exhaust sounds originate from the manifolds!lol!).....Also guys, my milltek system is resonated. This "resonator", is it part (is it inside) the centre box, or is it a seperate part built into the straight tubing?
    !!BINGO BONGO!!
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,866
    Yes it will be in the centre box.
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    Gotcha. Funny thing is I had a powerflow centre box put on there without a resonator in it, and it didnt make even a slight difference! Then I put the milltek original centre box back on and it changed nothing! What I'm after is something a tiny bit louder than what I have now (de-catted/full milltek system)without it being silly loud! I had the centre box bypassed with a straight pipr for a few days and the thing was so noisy it sounded like 10 saxos!lol! Will a differnece back box for instance change the sound/make it a bit louder? Was looking at this one instead of the milltek back box.......TRUST Exhaust Muffler Subaru Impreza GC8 WRX STI Ej20 on eBay (end time 05-Jul-11 10:48:05 BST)
    !!BINGO BONGO!!
    "Stick a V8 in it!"
    14,900
    On the S4, the "link pipes" are where the resonators are afaik, not the middle box itself. The link pipes sit between the standard downpipes and the Y section you mention.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    PowerFlow was the first mistake, the dealers don't have a flipping clue about even the basics of exhaust design. They opt for the throw generic boxes on with pipes done on a compression bender and make it sound "phat" approach which usually yields a loss of power over the original standard item.
    Anyway I digress, my experience with my car (albeit a 1.8T) the centre box seems to do most of the silencing. When swapping the back box for my custom one when I first got the car we ran it round teh block to see how loud it was and it was next to silent!
    I would be inclined to either put up with it or speak to a proper custm exhaust place like Hayward & Scott about having a system properly spec'd and built for you. The later of which won't be cheap but I can promise (having seen their work) that it will yield the results.
    Life begins at 140mph
    www.passionford.com
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    Interesting point. Yes the middle box on mine sure as hell does all the silencing. When I took it off it sounded like a pissed off hornet which was not nice (I have anaphalaxis!lol!)......The only thing I can think of now (shy of getting another system built from scratch) is to swap out the resonated mid box for a non-resonated one whilst still retaining the midbox itself.....
    Aragorn, you knowledgeable old bean, I think I know what your on about. There is a section about 4 inches long that "bulges" on the link pipe. Always wondered what it was? I will get a pic up........
    Its where the arrow is pointing to. Its a small cylindrical kind of chamber on one of the pipes. Any ideas?
    !!BINGO BONGO!!
    "Stick a V8 in it!"
    14,900
    That could be it.
    I've never seen them personally, but a few folk on the S4 forum have mentioned that miltek sell the non-res link pipes for about £50 if you want a bit more noise on a resonated S4 system.
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    Might just get that bit chopped out. Its pissing me off now!
    !!BINGO BONGO!!
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,503
    Slight hijack, but i'm toying with putting my decats back on and having a straight out exhaust from each bank.
    Would this work?? Or will it need an 'X' pipe in place so it can draw gasses from each bank??
    Dan
    2002 2.5 V6 Quattro
    "Stick a V8 in it!"
    14,900
    It can work, but i'd imagine it'll probably benefit from an X pipe.
    Twin pipe systems are available for the S4, but they typically share boxes, which presumably has some of the effect of an X pipe.
    Also, there really isnt much room under there for the second pipe on the drivers side with its own backbox, the fuel tank and spare wheel well are in the way.
    S4_dan's Avatar
    Jan 2006
    1,503
    How do other people fit dual exit exhausts then on the V6 Q's??
    The garage who fitted my S4 stainless system didn't mention the X pipe bit but said he could fit dual exhaust to it. I'm sure he knows what he is doing though. As i've seen three Ferrari's in there and an Aston Martin on the two visits i've made.
    2002 2.5 V6 Quattro
    May 2010
    Bedford
    2,877
    Obviously both pipes would run into the middle in the tunnel and then seperate again to either side onto the backboxes. They just wouldnt be like your picture. Sort of a cross between the two but still using seperate pipes from each bank and no x pipe.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    "Stick a V8 in it!"
    14,900
    What i mean is that you cant fit two backboxes. There isnt room.
    On a Quattro, the fuel tank sits on the drivers side where the backbox sits on the passenger side, and the wheel well is in between the two.
    If you want two tailpipes, you'd have to take a branch off the existing backbox and route the pipe round the wheel well, ending in a tailpipe with lots of insulation so the tank doesnt melt.
    S4_dan's Avatar
    Jan 2006
    1,503
    well I don't want to melt the tank and have a leak. The car uses enough fuel as it is!!! lol
    Ok, so might just look to get a system from cat back with twin exit like standard but have S4 Slant cut tailpipes
    2002 2.5 V6 Quattro
    "Stick a V8 in it!"
    14,900
    Heres a photo, but bear in mind this car has the spare wheel well REMOVED.
    You can see the outline of where it would have been, and hopefully can understand why you couldnt fit two backboxes.
    You MAY get away with MRC's approach, with a single middle box and carefully route the pipework around the spare wheel well, but there really isnt much room to tuck it up out the way on the drivers side, which would significantly reduce the ground clearance.
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    Slight hijack! Jesus! lol!
    !!BINGO BONGO!!
  28. #27
    "Stick a V8 in it!"
    14,900
    Its just an example of an extreme solution to your whispy noise :P
  29. #28
    S4_dan's Avatar
    Jan 2006
    1,503
    Quote Originally Posted by phoenixv6quattro View Post
    No point in doing things by halves!! lol
    2002 2.5 V6 Quattro
  30. #29
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    !!BINGO BONGO!!
  31. #30
    S4_dan's Avatar
    Jan 2006
    1,503
    Ah, but it also helps towards possibly removing the join in your car and preventing the 'whispyness' you have.
    2002 2.5 V6 Quattro
  32. #31
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    !!BINGO BONGO!!
