EM TuningVolks Autos
Thread: EGR valve
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,656
    EGR valve
    Any one removed the EGR vavle and blanked it off or know where to get the blanking plates from?
    I've done the normal set up, remove the pipe and blank the ends off.
    But there is oil starting to drip from the blanked off EGR valve.
    You can see where oil is dripping out and covering the oil feed pipe for the turbo.
    I did try the putting the blanking plate where the EGR is but they a couple of mm to big.
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    i would guess its leaking under boost pressure?
    TD5 Land Rover Defender build
    TDIPOWARRR
    Jul 2010
    618
    Same problem here, I've taken the plate off before, cleaned all the oil back out and re-fitted, 2 weeks later the oil is slowly dripping again, damn annoying.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,656
    Aragon, any way to test?
    I'm tempted to get two gaskets and put the together, see if that helps but I got a feeling its coming from the bolts.
    I keep meaning to try and make a blanking plate but I don't have the kit here or the metal to do it.
    Any one got any ideas?
    "Stick a V8 in it!"
    14,907
    if it were mine, i'd have it off, thoroughly degrease with solvents, and refit it with gobs of good quality sealant, ensuring its fully cured before running the engine.
    Jun 2011
    Dorset
    I don't know if it helps, but I used the lid off of a cat food tin to make my blanking plates, which I cut to shape using a pair of scissors.
    Not had any issues at all.
