Chris NottSky Insurance
Results 1 to 10 of 10
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    How do you change the passenger side indicator bulb?
    Mornin guys,
    Prob just me having big hands lol but how do I change the passengerside indicator bulb, I cant get in enough to twist the holder out. I dont fancy taking anything apart just for a bulb or to pay some spotty teen in Halfrauds £5 to do it haha!!
    J
    1996 A4 B5
    1.9TDI SE
    Gone but not forgotten
    Audi A4 2.5TDI Quattro
    Skoda Octavia 1.9SDI (Wont be missed lol)
    TDIPOWARRR
    Jul 2010
    618
    If your pre-facelift just pop the indicator out, all you have to do is push a little lever type thing down and the indicator unit will slide out.
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,633
    If post-facelift (one piece lamps) its easy to take the lamp out. 3x TX40 bolts....
    Currently rolling in a SKODA!!!
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    Cheers guys my car is a pre-face lift from 96 with one piece headlights separate indicator did look for a tab to try and get indicator out (if someone could post a pic would be awesome) so may just resort to taking it apart got a 350mile trip on friday and dont fancy doin it with the bulb out and the extra speedy indicator flash!!
    J
    1996 A4 B5
    1.9TDI SE
    TDIPOWARRR
    Jul 2010
    618
    Audi area: Audi TT DIY B5 A4 (Pre-99.5): BPV / DV Install
    That's the best pic I can find, the top one.
    If you look at the side of the actual headlight you can see where the indicator slides in to join onto the headlight, thats where the tab is that you need to push down to release it from the headlight.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    Here you go... took this when I first had the same problem! You can see a little phillips plastic screw head. You need to turn that 90 degrees, then push down. The whole indicator will slide directly forwards. When you're all done and slot the indicator back into place, remember to turn the little screw thing again or it can fall off.
    Mo power, mo problems
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    Fantastic help guys, ill get it out one way or another!!
    J
    1996 A4 B5
    1.9TDI SE
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    TD5 Land Rover Defender build
    Keyser Soze's Avatar
    May 2011
    Wirral
    81
    Change the man!!!!!
    '01 A4 1.8T Avant Sport Manual - Ming Blue Pearl (daily workhorse)
    Done - Brembo Max Discs & Pads, PIAA White 4300K H7 bulbs - VERY DEAD - CAMBELT SNAPPED 7th July '11 on the M6
    '01 A4 1.8T Avant Sport Auto Tip - Ebony Pearl (all back together now but still a little poorly ) - I've had enough of it time for bye bye
    Otherwise both unfettled & unfiddled
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    Cheers guys again, right, pry bar applied and bent the wing outta the way easy access lol!!
    Ill have to have another proper look as I cant seem to find either a tab or the twisty 90degree thingy down the whole...more investigations required!
    J
    1996 A4 B5
    1.9TDI SE
