Sky InsuranceChris Nott
Results 1 to 10 of 10
Thread: EGR DELETE
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    EGR DELETE
    Hi,I am looking into removing the egr system on my 2000 Audi A4 1.9 TDiajm engine.As the valve is built into the inlet system,I'm thinking of blocking the pipe off at both ends.Will this be ok?
    thanks in advance
    tony
    May 2011
    Wigan
    12
    Well mine's a 1.9tdi 1999 model . Post a picture of the inlet and Egr , id imagine the they are same. If they are its really quite simple to do.
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    here is a pic
    tony
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,391
    remove and blank the metal pipe that runs between the inlet and exhaust manifold.
    TD5 Land Rover Defender build
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    thanks,I thought that was the case but thought I'd check.
    tony
    May 2011
    Wigan
    12
    Grab yourself 2 plates off ebay , They're pre cut for a direct fit .
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    Quote Originally Posted by craigg9700 View Post
    thanks Craig,but would rather make my own than spend £5 on 2 small bits of steel.
    tony
    "Stick a V8 in it!"
    15,391
    Can probably use a slice of coke can and then reinstall the pipe over the top.
    TDi Powerrrr
    Aug 2010
    North Devon
    405
    have got some 3mm steel so will use the gasket as a template and make some up.
    tony
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,651
    Tried that on my old vectra diesel. Its not strong enough, the exhaust gasses bust a hole right through it wondered why the feel of the car changed suddenly haha.
    Currently rolling in a SKODA!!!
