Badger5Chris Nott
Results 1 to 17 of 17
    Mar 2004
    Cheshire
    922
    Service nightmare!!!!! ŁŁŁ
    Hi
    I've just had my 120k mile service and have been told the following need changing...
    All round brakes (although rear disks might be ok)
    New cat as the flexi hose is split
    CV boot split
    Rear exhaust box corroded
    and possible valve seal problem as spark plug on cylinder 2 shows oil consumption problem.
    So I can do the brakes myself for a Ł100 parts, who are decent manufacturers so I don't buy crappy bakes?
    Can the flexi hose be repaired on the cat or do I need a new one? How much are they?! Seen one for Ł150 exc VAT and delivery. Can you get cheaper?
    And if my engine is using a bit of oil (0.5l every 1200 miles ish), is this damaging the engine - ie do I need to get the valve seals done as it's a Ł440 job! Could I just try using the thickest grade of oil audi approve of?
    Thanks for anyones help as the garage have said the cat would be Ł350, brakes Ł340 etc ............. help!!!
    Mar 2004
    Cheshire
    922
    Re: Service nightmare!!!!! ŁŁŁ
    oh cambelt has already been done btw!
    Sep 2003
    London, UK
    53
    Mate,
    That aint a nightmare! This is a nightmare.
    I took mine it for its 160,000K service (LOL)
    Even thought it has been serviced reguralrly - i'm gonna need Ł1500 quid worth of stuff to get it thru the MOT (audi dealer prices)
    AND
    a new Clutch and gearbox!? (2200 quid)
    Ł1500 + Ł2200 = Ł3,700
    Thats a mare!!!!!
    Jun 2003
    World of my own
    9,813
    Why the hell are you taking a 160k mileage car to an Audi dealer?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,678
    [ QUOTE ]
    [/ QUOTE ]
    Hear hear!! What part of London are you based in? If you're anywhere near SE London or North Kent, these are the people to take it to.
    http://www.sanspeed.co.uk/index2.htm
    madkebab's Avatar
    Dec 2003
    South West
    396
    AJ - For brakes you could try GSF, think they stock Zimmerman which I have used before and seem to be pretty good. If you use Partco or the like go for Brembo standard replacment discs and maybe some ferrrodo pads.
    I cant see why you would need a new cat if the flexi pipe is damaged, The flexi is part of the downpipe and as far as I know the cat and downpipe are seperate parts. Someone correct me if Im wrong but im pretty sure thats the case.
    Nov 2004
    Kent, UK
    138
    Try Vagparts.com for genuine part prices on the brakes. They might not be that much more expensive to pattern parts.
    If the flexi is part of the cat pipe a custom exhaust builder may just weld in a new flexi for you.
    If the rear box is knackered it is a great excuse to get a performance one!!
    Half a litre of oil per 1200 miles is not necessarily excessive. However, if it is a valve stem seal it is not going to get better and will get gradually worse. It is not doing any damage to your engine as long as you keep an eye on the oil level but your fuel consumption and perhaps a bit of performance will suffer.
    Jeff,
    I am assuming you are in Bexleyheath?
    John
    Mar 2004
    Cheshire
    922
    Thanks fr the replies and I agree that manikm wins hands down for nightmares!
    I'm going on holiday skiing tomorrow, so will get stuff when I get back.
    Very interested in the idea of welding in a new flezi pipe. Madkebab, from what I could tell from looking under the car, the flexi pipe is right next to the cat, ie 3 inches apart, so i reckon it's prop part of that?
    QuantumJohn, funny you should mention about fuel consumption, as I have noticed it is bad. I prob get 85 miles out of Ł10, but then I do a lot of town driving as well. Think I'll just check the sparks in a 1000 miles time. The garage did mention about only filling half way on min-max dipstick so that less pressure is exherted.
    Will try vagparts and GSF to see how much!
    Thanks guys! Was absolutely gutted when they told me it needed so much spent (a lot to me!), started looking at insurance on a fiesta!! But i adore my car and couldn't do that!!!
    Nov 2004
    England, UK
    63
    guys I thought audi dealers charge a bomb for labour (Ł95+VAT per hour), but BMW seem to charge even more. Got my bmw service from dealer, they charged Ł105+VAT an hour. I take it mercs cost even more. So Audi is the cheapest out of the german rivals, but seems to be more unreliable so ends up costin more gettin the fixes done.
    Nov 2004
    England, UK
    63
    hey my cat needs replacing too, but ive got a 1.8 non turbo. So i just need the CAT. Will prob get from eurocarparts or german and swedish. But for what i know, the turbo cat comes with the down pipe attached, where as i just get the CAT. Oh and i think mines is the one without on board diagnostics, unlike the turbo one and newer ones.
    by the way audi quoted me about Ł800 to replace the cat !!!!! kwikfit said Ł220 - but they are normally crap. Eurocarparts and G&S do it for under 100. Oh and VW and Audi parts do it for Ł140 - better quality with 2 yr guarantee. http://www.audivwparts.co.uk/
    so am still deciding what one to get
    Nov 2004
    London UK
    2,614
    How the hell can Audi quote you Ł800 quid i mean look at the difference in prices that is just crazy!!!! It really p!sses me off this blatant ripping off!
    Nov 2004
    England, UK
    63
    For the parts alone they said Ł259.99 +VAT for the catalyst and Ł5.20+VAT for the gasket - as long as my old parts are still recyclable as they want them back. So the rest will be their labour charge. This was from the lee valley audi.
    Here is the quote i got from eurocarparts 69.99 for cat and 3.00 for gasket. 1yr/12000 mile guarantee.
    Jun 2003
    World of my own
    9,813
    It costs quite a lot to hand craft the 4 ring logo onto another manufacturers CAT.
    Nov 2004
    London UK
    2,614
    [img]/ubbthreads/images/graemlins/lol.gif[/img] i bet
    Mar 2004
    Cheshire
    922
    hmmm ....
    yaseen i've looked at my cat and i'm pretty darn sure the flexi pipe and cate are 1 piece as they are 3 inches apart from each other. Can't see anyjoings between them so just assume it must be a downpipe, flexi and cat all in one costly pipe!!!
    so i'm not too sure now as from what i've seen on parts catalogues, the cat is seperate to the downpipe on pre facelift models, ie mine, but when i look under the car, it looks all one piece!
    imported_Yaseen
    Do you have the ADR engine? my pipe was replaced before by previous owner so I saw the old one and definately was just the pipe changed- exactly like this pic:
    maybe different on urs Aj. Normally on the cat outlet there should be bolts where the downpipe is attached.
    Mar 2004
    Cheshire
    922
    unfortunately mine ain't that sort. i've looked under my car and the flexi hose is longer and then goes straight into the cat.
    I've checked on a '95 A4 and the pipe looks just like the one on that pic.
    Think with mine being 01/99 (but prob week before new facelift) they might have used the facelfit cat?
    I've looked into the brakes and all looks pretty simple for the brakes.
    I need to change the brake hose and was wondering which pipe you need to change. There is a very thick one going into a metal solid pipe and then a thinner one going into a rubber pipe. The metal one goes to what I assume is the ABS pump as there is an electronic plug on it.
    Does anyone know which pipe you change? or both?!
