EM TuningVolks Autos
    May 2011
    Wigan
    12
    Thumbs up Audi A4 1.9tdi EGR blanked and Inlet Cleaned
    After reading on the forums i decided to blank my EGR valve off.
    Glad i did , You should have seen the state of my Inlet manifold. The Thing was choked up with oily carbon sh**e.
    ImageShack� - Online Photo and Video Hosting
    To clean the manifold I used a blow torch down each hole(smoked the estate out lol). After i did this i also jetted water down each port with a power washer . ( you should have seen the crap that was built up in there it was unreal !!!!)
    To me the car seems to be pulling alot better now , i have also noticed a nice whistle as the turbo is spooling.
    Peace at mind now that all sh*te wont be going back into my engine ever again.
    Feb 2009
    228
    It really is quite unbelievable how these things even run with the amount of crud that builds up aand restricts the inlet.
    Nasty job cleaning It out though....
    Sent from my U20i using Tapatalk
    May 2011
    Wigan
    12
    Bloody is mate , Girlfriend had a fit when she saw all the crud all over the drive way , not to mension the carpit in the hall lol.
    at least mi inlets clean though haha
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    How much work was there in getting it all apart and is there a gasket between the inlet manafold and the block then needs replacing after?
    J
    1996 A4 B5
    1.9TDI SE
    Gone but not forgotten
    Audi A4 2.5TDI Quattro
    Skoda Octavia 1.9SDI (Wont be missed lol)
    May 2011
    Swansea South Wales
    I cleaned my inlet out today , took 2-3 hrs off and back on. pull off the snorkell and the air scope off the airbox to make a bit of room and get a few allen keys , take off the egr pipes at the turbo and the manifold and the rest come off easy, A new gasket was a few pounds from gsf , found a few loose boost pipes whilst i was at it. Can hear the turbo spooling up more at low revs now
    TDIPOWARRR
    Jul 2010
    618
    need to get mine done but one of the bolt heads has rounded so going to have to get it extracted somehow.
