Volks AutosSky Insurance
Results 1 to 9 of 9
    May 2011
    Wigan
    12
    A4 1.9tdi 110 , injector upgrade advice please.
    If i was to drop a set of 2.5tdi ( 0.216) injectors into my 1.9tdi (0.205 current) would the car run ok ?
    Or would the ECU need to be re-mapped ?
    May 2010
    Bedford
    2,877
    Think an adjustment in Vagcom is needed as they`re a bit smokey if you dont adjust something so people have said. Runs alright though apart from that.
    If you went through with it i`d have a buyer for your standard injectors anyway lol
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    May 2011
    Wigan
    12
    Thanks jason, ii'm gunna ask a few more questions with a mate on this one then. I'll hit you up if i decide to upgrade.
    cheers
    Feb 2009
    228
    Let me know how you get on, think .216 nozzles will be next on my to do list
    Sent from my U20i using Tapatalk
    Apr 2011
    37
    I'm probably the guy Jason's talking about
    T4 Injector nozzles on 110 - SEAT Cupra.net - SEAT Forum
    The injectors go straight on the only change the 110's need is an adjustment via vagcom to help the idle (think it'll run without the adjustment but idle is helped by that adjustment)
    Injectors on the 90 if you fit the .216's is a different story and a bit of a pain apparently - Only know this as I was looking at .216's for my 90 but decided it needed too many supporting mods and I've got my Skyline to waste money on instead
    Jul 2007
    London
    3,258
    You need to do the "hammer mod" wich involves moving the top part of the pump so it injects less fuel at iddle, very easy to mess up and you need full vagcom to see the IQ at iddle. I would not do the adjustment in Vag com as the mechanical adjustment is more precise and lets the pump have more control of the pump advance.
    FOR SALE:
    TDIPOWARRR
    Jul 2010
    618
    I'm wanting to do this to mine, is it just the .216 nozzles you need or the whole injector?
    Also does anyone know anyone that would do it for me? Don't have access to vagcom.
    I'm based in North Yorkshire.
    Jul 2007
    London
    3,258
    You need just the nozzles but they need to be tested and adjusted for pop pressures then you need someone handy to do the hammer mod. If you ever drive down south to London then i could do it for you...
    FOR SALE:
    TDIPOWARRR
    Jul 2010
    618
    Cheers for the offer, not been down to London in 5 years though so can't say I go often, is the hammer mod simply to stop the car smoking?
    Need to find a decent diesel tuning company that know what they are doing and have done this sort of thing before, or if anyone on here is fairly local to me and knows what they are doing(can't stress that enough) then I'll gladly pay someone off here to fit them and adjust them etc.
