Noticed dashboard gap between the windscreen and dashboard itself.
It seems wider on the D/S but very tight and normal fit on the passenger side.
I've had a go at adjusting the bolts easily accessible with no change. Had a look at some diagrams and Can't actually see what frame aligns the dash or if the dash should be aligned on the frame itself.
I just junked the aftermarket 'alarm' in my car and but not sure where two wires coming from the rear go. They were spliced into "flash" and "arm" on the alarm. But can't find any obvious point on the harness in the footwell where it was cut from.
