Sky InsuranceBadger5
Results 1 to 17 of 17
Thread: N75 upgrade
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,651
    N75 upgrade
    Can just replacing the n75 increase boost pressure? If so, what part no is best and what benefits?(more hp?)
    Car is a 2000 1.8T AGU A4,
    Thanks guys
    Currently rolling in a SKODA!!!
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Have a look at the ecs tuning one that's on eBay search n75 1.8t race valve here the description they give
    The N75 is the VW/Audi part identification number for the wastegate by-pass regulator valve. This valve is responsible for controlling the movement of the pneumatic actuator which drives the wastegate. The wastegate is an internal valve in the turbo-charger which controls the amount of exhaust gas that flows over the turbo impeller generating boost.
    Under normal operating conditions the engine's ECU sends signals to the N75 valve asking it to open or close which adds or reduces pressure on the wastegate actuator which results in more or less boost. The ECS RACE N75 valve modifies the normal operating parameters of the original N75 valve by delaying the speed at which these ECU signals are interpreted.
    The result is a higher initial peak boost and an elevated boost curve which tapers back to stock/chipped levels over the engines rev range. Average boost gains are 1-3psi over the rev band.
    Arrkon's Avatar
    Oct 2010
    1,651
    yeah spotted them, would fitting one from a 190PS 1.8T or even the 225PS TT engine do anything???
    May 2011
    6
    You need the N75J valve from an audi RS2, Spikes higher and holds boost longer.
    Arrkon's Avatar
    Oct 2010
    1,651
    Quote Originally Posted by S4 IRL View Post
    Great, just what i needed to know know a P/No?
    Oct 2009
    190
    Would the N75J be the one to use on my 1997 aeb?
    May 2010
    Bedford
    2,877
    They also cause it to go into limp mode...
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,097
    You can just adjust your existing N75 valve to make it come on boost harder. Free to do, well... as long as you don't break it.
    Life begins at 140mph
    www.passionford.com
    Arrkon's Avatar
    Oct 2010
    1,651
    Quote Originally Posted by Jason.s View Post
    As i understood it, the "H" variant causes limp, whereas the J doesnt?
    Quote Originally Posted by Oranoco View Post
    How can that be done?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,391
    TBH i wouldnt bother. All it does is give a useless and dangerous huge spike of boost when the turbo first spools up. The J valve has also been shown by Welly on here to allow the boost to tail off earlier, presumably as a result of the ECU trying to control the massive spike and pulling back the N75 duty cycle.
    TD5 Land Rover Defender build
    Arrkon's Avatar
    Oct 2010
    1,651
    ok, Just trying to come up with some cheap performance enhancing mods :D
    "Stick a V8 in it!"
    15,391
    The cars ECU is pretty sophisticated, and doesnt really take well to trying to fool it into doing things it shouldnt be doing.
    If this is a late car, then it has a boost sensor, so any fiddling with the boost is likely to see it drop into limp mode every time you stick the foot down. You can get away with a little bit more on the earlier cars, but that doesnt mean its a good idea either.
    You need to remap the ECU if you want more power, i've seen companies advertising remaps starting from £100.
    Arrkon's Avatar
    Oct 2010
    1,651
    £100 for a remap??? cheapest i've found is £200-250
    at 100 notes, its very tempting
    Keyser Soze's Avatar
    May 2011
    Wirral
    81
    Beware the £100 map................
    I myself personally have never had the experience of one but I have heard too many horror stories of el cheapo maps in the past during my Volvo T5 days.
    Same as always, buyer beware. If it seems too good to be true, then it invariably is.....
    Arrkon's Avatar
    Oct 2010
    1,651
    Ah, yes. Fair comment there Kev
    Nez
    Dec 2008
    London
    596
    Just be careful when you play with N75 last time I was in MRC and my car was putting 600Nm Torque because of faulty N75 and the guys at MRC told me to change it as soon as possible as I could blow up the turbo's...
    (Audi S4 351.9 PS, 603 Nm, MRC Custom Remap XS Power DP's, Cat Back Exhaust, Forge DV, RS4 Intercoolers, RS4 Breaks and Induction kit)
    Traffic Exchange Site http://www.limehits4u.com/
    "Stick a V8 in it!"
    15,391
    Was a company advertising postal remaps on ebay for £100.
    Sure its a risk buying a cheap map like that, but tbh they've probably just knocked off some other tuners maps anyway.
