needed urgent.camshaft cap,2.5 tdi
davek
NULL
hi
does any body have a camshaft bearing cap laying about.
Its the one that holds the front oil seal behind the cam/pump pulley.
thank you in advance.
dave king
you cant really just swap a cap...
The cam bearings are line bored with the caps torqued down. A cap from a different engine wont be the same as the one on your engine.
Hi
I have not got a pictureas it is still fitted.
Its the bearing that hols the cam and oil seal at the front of the head.
It has a bit sticking up from the top with a threaded hole in.
The bit tha is broken on mine is the part that holds the oil seal,i was going to weld
A bit off the replacement to it.
thanks.dave
