EM TuningChris Nott
    Feb 2011
    32
    2.5 tdi camshaft timing help needed
    Hi
    Had to change one of my camshaft pulley's.
    I need to know how to time it up as i cannot find any position marks.
    So what i need to know is...
    Crank timing mark and cam timing marks.
    I have searched all over the net for a diagram without any luck.
    Hope some body can help please.
    thank you in advance.
    dave king
    Jul 2007
    London
    3,247
    You need locking tools to time the engine and its not that straight forward as it seems ! Where abouts are you based ?
    FOR SALE:
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,612
    On my 2.8 V6 you are supposed to use a locking tool on the 'wings' on the cam sprocket. however i didn't. With the rocker cover off there are some marks on the cams, little arrows. I lined these up and used them. and also made sure that the wings elongated holes were on the outside not the inside. I wish i had taken a pic of the said marks now but i didn't.
    2002 2.5 V6 Quattro
    Jul 2007
    London
    3,247
    The pulleys on the camshafts on any v6 2.5 tdi engines are tappered and they need to spin whilst you lock the cams within the slot on the back of the head, then the crankshaft needs locking at TDC, then you can tension the slack off the cambelt. Afte r the belt is fitted the pump needs locking with the pi at TDC then when the engine starts, it needs slight adjustment of the pump via the 2nd sprocket on the right hand side cam sprocket. There are no timing marks provided for the v6 tdi engine- unlike on petrol engines where timing is taken care by the cams hydraulic adjusters- where the timing is done by the VP44 pump...
    FOR SALE:
