EM TuningAH Fabrications
Results 1 to 9 of 9
    gmx
    Feb 2009
    Sydney
    132
    B5 Audio issues & Replacement
    Has anyone come across cheap fix for the Concert I HUs or any seller/repairer that sells a replacement or better IC for DIY soldering?
    I'm also looking to replace front speakers with an adapter to 130mm
    Do I need to replace the tweeters or can I leave them?
    Is there an OEM "crossover" in place? If so, can I just reuse that with replacement aftermarket speakers?
    00 A4 1.8TQS GP MT AJL
    JHM SSK | FX300 + 16lbs FW | Milltek Dump back
    17*8 BBS RK | Deka ETX20L | Vogtland GT 575F/675R | H-Sport 35mm(F)/22.5mm(R) ARBs
    034 Engine Mts | Stern Snub/ Rear Diff Insert/Power Ring
    GT2871R - 13psi | Uni 415cc@4bar | 034 3" DP | 034 HFM | 034 TIP | Profec B Spec II
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    OEM crossover is an inline capacitor.
    I've left the speakers alone, but driven them from a proper 4 channel amp. Totally transforms how they sound.
    I also dumped the concert as its pretty rubbish, the aftermarket head unit also improved the sound quality no end!
    TD5 Land Rover Defender build
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    2,870
    I would definitely get rid of the concert there living in the dark ages of sound quality !
    Mods - Frankenturbo F4 Kit - THS Decat - Milltek - ECS Crank Pulley - 034 Snub + Bracket/Gbox Mounts - 1Z/S2 Clutch + Flywheel - 007p - ICM + EVAP Delete - S4 B6 345mm Brakes - 300mm Rear Brakes - Goodridge Hoses - LCR Splitter -S4 Bumbers + Skirts/Mouldings - OEM Xenons - Apikol Diff mounts - Polytek'd Rear Diff Mount
    To do - F21 Upgrade - 3" Maf/Saab red Injectors
    WANTED : Cheap 02/52 Passat 1.8T AWT Manual
    gmx
    Feb 2009
    Sydney
    132
    I'd love to but I'm on a tight budget. Already stretching it by choosing to replace the front speakers instead of reglueing the dust caps on the Oem ones.
    The std sound system is fine for me. I'm not an audiophile - nor do I have the ears to be one!!
    If anything I would probably just get another used concert for $50 (yea, it will eventually fail) but the volume isn't so bad yet.
    With the OEM crossover being inline I guess it would as simple as using the existing wiring.
    With random googling I've come across some threads where plastic adapters are a nono but none of them explain why. I suppose it's due to the additional vibration they may induce as they're not a part of the abs injection molded door trim (1 piece vs 2).
    Has anyone gone from 4" to 5.25" using any of these:
    Audi speaker adaptors Fitting Adaptor - Car Audio Direct
    CT25AU03 Speaker Fitting Adapter for Audi A4 Front Door 130 mm
    Autoleads SAK-1104
    Jun 2003
    World of my own
    9,813
    They are all rubbish, nothing to do with vibration, just the fact they don't fit properly and leave a huge gap between the new speaker and the baffle. TBH if you are leaving everything else stock then upgrading just the speakers is a waste of money, it may even sound worse. No aftermarket speakers will sound good screwed to a flimsy door card and driven from the 2 x 12wrms the Concert "kicks" out
    Alex Turner
    Mar 2011
    suffolk
    249
    ditch the concert there nothing but trouble plus sound is like from a grammerphone compared lol
    heres what i did to give you an idea
    am getting the blue parts recovered soon in the same cream leather but still sounds awsome
    Apr 2011
    macclesfield
    38
    or you could go for something like this..
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    its all down to the install and proper use of materials but still the a4s are very poor design when installing speakers
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    gmx
    Feb 2009
    Sydney
    132
    Looks like my post didn't actually... post here.
    Just for reference and if anyone else comes across this in the future.
    I've decided to just go with a minimum cost approach since music/audio is just not one of my interests.
    I will be repairing/reglue the standard speakers.
    Remanufacturered concert for about $20 - swap microprocessors. It's a US version so I don't think it'll work here..
    Soundproof the door card and inner skin moderately.
