Volks AutosAH Fabrications
Results 1 to 8 of 8
Thread: Ecu on eBay
    Oct 2009
    188
    Ecu on eBay
    Hi all just wondering if this ecu would be a plug and play or need coding of some sort?
    Item Specifics
    Intended Use: Modification/ Enhancement
    Type: Computer, Chip, Cruise Control
    Subtype: ECUs
    Chipped ecu for Audi A4 and Passat 1.8T AEB engine code (may fit others as well)
    From 1997 to 1998 cars
    Bosch Number 0261204179
    VAG Number 8D0907558M
    1st Stage programmed for stock engines. Will give 200bhp
    Can remove immo for an extra 50 pounds so it can be used without the stock cluster / key.*
    For any questions please do not hesitate to contact us.*
    Sellers: Get your own map of past buyers. Fast. Simple.
    supreme
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    If your car is immo 1 or 2 it should be easily configurable with Vagcom.
    What age is your car?
    TD5 Land Rover Defender build
    Oct 2009
    188
    1997 aeb, 200bhp is a tad optimistic tho.
    "Stick a V8 in it!"
    14,900
    Yeh the turbo will only really flow 190-195 in real terms.
    Should more or less drop in, you will need to use vagcom to match the ECU to your IMMO unit but its really easy to do.
    Oct 2009
    188
    Ok mate thank you, now just waiting for my tax rebate to come through then let the mods commence!!
    Oct 2009
    188
    As it says on the advert, would it be worth 50 to remove the immo? Or would vagcom over come this?
    "Stick a V8 in it!"
    14,900
    No leave the immo alone, you just reprogram it to your car, which can be done easily with vagcom on a car as early as yours.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    I have a mate with full VAG Com who's very local. Cam ask if he can do it for a couple of beer tokens.
    Knew you'd get the answer on here
    Life begins at 140mph
    www.passionford.com
