Volks AutosSky Insurance
    Nov 2010
    19
    Anyone know the rocker cover torque settings on a 2.4?
    My current rocker cover gaskets are leaking in to the spark plug wells. I've got replacements but before I start going about doing the job, I'd like to know the torque settings if anyone knows them?
    I've been looking around and I can't seem to find anything for this specific engine.
    Thank you!
    Nov 2010
    19
    Nobody?
    Ross_S4
    Aug 2009
    Dundee
    718
    What engine is it?
    I believe the correct torque spec is 10Nm. do the two inners first then the outer nuts diagonaly.
    Nov 2010
    19
    That's a good question! I'll check later/tomorrow.
    I know that the 1.8 and 2.8 need 7lb of torque, which is near as makes no difference 10nm, so you may indeed be correct!
    Thank you for the reply.
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,505
    Rossbrownlee is correct. It's 10nm on the rocker cover according to Autodata.
    2002 2.5 V6 Quattro
