AH FabricationsJMB Retrofits
Results 1 to 34 of 34
    May 2010
    Bedford
    2,877
    Poly snub mount options..
    Phoned up Awesome and they dont have any of the old APR mounts anymore and they were pretty sure that the Neuspeed one for the B6 doesnt fit due to different shaped holes. I`d like one before i get my cambelt/clutch/fly done which hopefully should be soon so getting one from America is effort and takes too long.
    Anyone ever made their own?
    I also wondered what the RS4 one would be like, if it was any harder and so on. On ETKA it lists it as the same as the 6 cylinder Passat Diesels engines so have ordered a standard one for the A4 and an RS4/Passat diesel to compare. If its beefier and roughly the correct internal diameter then i`ll use that but if not then its back to the drawing board.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    Neuspeed one fits fine.
    The hole is a different shape, but it goes on all the same.
    Had one on the old FWD but it went with the car. Perhaps i should go steal it back, mums never going to notice the difference :P
    TD5 Land Rover Defender build
    May 2010
    Bedford
    2,877
    haha well thats alright then. Will see what this one i`ve ordered in looks like. If its pap and looks like it`ll do no better than standard one then i`ll order Neuspeed one. Far too much movement in the gearstick when accelerating and letting off even with brand new engine and gearbox mounts.
    "Stick a V8 in it!"
    15,381
    Did you uprate the engine and tranny mounts when you replaced them?
    I've got a pair of used S4 ones to go on shed, and they're much stiffer than the ones i removed!
    jcb
    Sep 2005
    uk
    4,077
    The hole is a different shape, but it goes in all the same.
    now there is a quote for life!!
    May 2010
    Bedford
    2,877
    I was going to order RS4 mounts but didnt have 150quid(COST) to spend at the time plus i couldnt be arsed to order from Audi so i got brand new standard ones for nothing including gearbox mounts to which i found when i changed the n/s gb mount it had detatched itself from the metal housing and was near enough hanging out lol. Made it all a lot better but still not enough for my liking. The standard snub mounting is pretty useless. Squishy useless piece of foamy rubber so hopefully this different one i`ve ordered is better as it`ll only cost me a few quid at cost.
    "Stick a V8 in it!"
    15,381
    yep.
    I took my tranny mounts off the shed while its engine is out and i've filled them with polyurethane sealant. Did the same with the rear diff mount. Unfortunately the engine mounts are fluid filled and theres no void to fill will sealant so they'll be going on as they are.
    Will probably get a neuspeed snub, as they're pretty cheap.
    May 2010
    Bedford
    2,877
    Yeah thats what i did lol.
    Neuspeed one is pretty cheap indeed. 31 odd with delivery and on ebay from Awesome atm. Im pretty sure the old APR ones were more and they didnt look as good as they were the same as the standard ones but poly instead so wouldnt squish. Neuspeed shouldnt really move all that much at all which is good. Will know by friday if i need to order one if this RS4 one is useless
    AndyC's Avatar
    Apr 2003
    Dorset
    717
    got one from 034 with the new housing as well... seems to be good.
    I am getting some harder mounts made for tranny and engine over the next few weeks.
    there is no such thing as bad weather, just the wrong clothes!!
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Link to Neuspeed mount please?
    Project RS28 build
    Apr 2010
    10
    Can u tell me the feelings ?
    how do they effect the comfort and performance ?
    A4 1.8TQ - Turkey
    May 2010
    Bedford
    2,877
    Neuspeed Audi A4 1.8T/2.0T Engine Torque Damper Bushing on eBay (end time 06-May-11 15:09:42 BST)
    Or direct from Awesomes site
    Awesome - Neuspeed Audi A4 1.8T/2.0T Engine Torque Damper Bushing
    The 034 kit is good but it`s too expensive when you can get the Neuspeed jobby for 31 delivered
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    yep.
    You happy with those mounts Kev? Told you they were in good nick!
    I bought the 034 track density engine mounts. They are solid, but I compared them next to the stock mounts and there is a void on the stock ones which could be filled with something like Tigerseal. It's like a ring around the top of the mount.
    Anyone know if the 1.8T and S4 snub mounts are the same? If so, I can measure my JHM snub mount when I get home for you.
    Mo power, mo problems
    May 2010
    Bedford
    2,877
    Yeah its the same. Its only the 2.5 diesels and RS4 mounts that are different to the rest.
    "Stick a V8 in it!"
    15,381
    Scott: Aye mate they're spot on, nice and tight unlike the snapped ones i removed.
    May 2010
    Bedford
    2,877
    RS4 mount it is
    You can squash the standard one so the hole in the middle is almost closed together with one hand. Try doing it with the RS4 mount and its solid! it doesnt compress even 1mm unless you use 2 hands and really squeeze it and even then its a struggle. That`ll be going on when the rest of the work gets done.
    Its only 10.68 inc vat so should be a nice cheap way of reducing movement.
    Feb 2007
    Liverpool
    1,693
    Anyone want my S4 one before it goes in the bin? That's solid rubber as well.
    "Stick a V8 in it!"
    15,381
    go on then, so long as its nice and stiff like jason says the RS4 one is
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Does the mount for 1.8 do mine aswell?(2.8 v6 Quattro)
    Or is the RS4 one just as good, and cheaper alternative??? Is it fitted and tested yet?
    Project RS28 build
    May 2010
    Bedford
    2,877
    Will be fitted and tested hopefully in the next month when all my work eventually gets done. yours will be pretty much same as the 1.8t im sure but cant be 100% without looking at work.
    RS4/2.5 diesel is the best OEM option and is only a tenner
    jamie226bhp's Avatar
    Aug 2009
    464
    Any one got the part numbers of these mounts as I'd like to change all mine on my 2000 1.8 tqs
    May 2010
    Bedford
    2,877
    Which ones you after? standard ones or better OEM mounts? like RS4 or something?
    Aug 2009
    464
    All of them gradually for Better oem ones as long as they don't break the bank
    May 2010
    Bedford
    2,877
    Left, right and snub RS4 mounts including the vat comes to 217.68. Gearbox mounts you`d be better off doing as Aragorn did and fill them with tigerseal to stiffen them up
    left and right is 8D019979AD and snub is 8D099339E
    Aug 2009
    464
    Is it a genuine Audi only item or are gsf ones ok
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    i dont think the rs4 snub will be a tight enough fit in the mount to make that much difference, plus its rubber so will deteriorate
    the neuspeed one you have to ignore b6 fitting instructions and turn through 90deg then its a very tight fit in the b5 mount (it probably works better in a b5 than a b6)
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
  28. #27
    "Stick a V8 in it!"
    15,381
    Its not really supposed to be a tight fit, as if it is it transmits huge amounts of vibrations into the car.
    The idea is that when the engines "at rest" the snub sits centralised in the housing but not touching it. When you load it up the engine naturally tries to lift and the snub then comes up against the housing stopping it moving any further. Ideally you want a very small airgap of no more than a milimeter or two, and with a stiff mount this typically works fine, giving a decent balance between comfort and performance.
  29. #28
    May 2010
    Bedford
    2,877
    Yeah pretty much^
    If i wanted it solid then sure but my ex had pretty much solid engine mounts in her Celica GT4. Sure it was a track car but jesus the vibrations were shocking and you could watch the bonnet vibrate more than having a huge sound system.
  30. #29
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Just to resurrect this thread for a min... Was the definitive answer for a snub mount upgrade the RS4 item pn 8D099339E ?
    Got to do the belts at some point this summer and thought I might as well do the snub too
    2000 1.8t quattro Sport totally standard (ish)
  31. #30
    "Stick a V8 in it!"
    15,381
    Quote Originally Posted by NineNails View Post
    Its 8D0199339E!
  32. #31
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    Well spotted Kev cheers!
  33. #32
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Geeman has one for sale, ad is on SRS but hes on here aswell, maybe pm him?
    Project RS28 build
  34. #33
    NineNails's Avatar
    Sep 2006
    North Wales
    579
    Cool, cheers. I'll shoot him a PM
  35. #34
    Biodiesel Purrrr
    Jun 2011
    London
    150
    As the V6/RS4 snub mount is the cheapest to replace I'm planning on starting with this one...
    Can the part be fitted without moving the engine or pulling front end of car out?
    TDi Biodiesel sippin' A4 Avant - EGR blanked
    "Cars are good but Jeremy Clarkson is a dick."
