Volks AutosEM Tuning
    Mar 2004
    Minnesota, USA
    Climate Contol and other lights
    Recently, all the lights that illuminate the buttons on my climate control, and the lights for my heated seats, fog lights, rear deforst, and hazards went out. It is just the red lights. The lights that turn on when the buttons are pressed still work. It is just the red back lights. Anyone know what this could be??? I was doing work behind the climate control and such so I could have knocked something...but I have no idea what to look for. Any help is much appreciated.
    Thanx
    Mar 2004
    Cheshire
    922
    Re: Climate Contol and other lights
    check your fuses.
    try fiddling with the wires to see if you've knocked summit loose
    other than that you'd have to get your multimeter out and test the circuit for power.
    Nov 2004
    England, UK
    63
    yeh i had a similar problem mate, it was a dodgy fuse. Check that first before doin nething.
    Mar 2004
    Minnesota, USA
    I check all the fuses...they are all good.
    Oct 2004
    Near Baltimore Maryland
    66
    Well if the problem didn't come up until after you were messing around behind there i'd say there was a good chance you knocked something loose. Just take a look, if you were back there before just look around for anything that looks to be obviously disconnected. Hope for the best man.
