Well, came off the moterway tonight after my 60 mile commute home to discover the clutch pedal has gone really light and the clutch is beginning to slip.
Symptoms:
Light pedal with little/no "push back" from the clutch pedal
vibration when engaging the clutch
Car is on 194k and I imagine the original clutch, the biting point has been pretty much at the top of the pedal travel as long as i have had the car (6 months) so i expected the clutch would go in the not too distant..
Big problem is time and money - isn't it always!
I'm aware that there is a SMF flywheel and clutch conversion, or i could just go down the stock route.
Question is what would you replace the clutch with and roughly how much it would cost
If i could picck up an oem clutch kit what else would i be advised to change whilst it was all apart?
if i go down the SMF route can you point me in the direction of part numbers and suppliers.
Time is a massive factor here, i do 120 miles to and from work a day and this week (year end) is probably the busiest week at work for me. So I'll be looking to get this repaired asap to avoid having to commute on the motorbike in the rain.
You may now take the floor...............
Symptoms:
