Badger5AH Fabrications
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,086
    Project "Pinky", couple of teething problems.??
    Project Pinky is finally alive and in use. Couple of really annoying teething problems which I could do with some suggestions on.
    1. Speed isn't working.
    2. Bottom Rad hose keeps popping free and leaking.
    Only other issues are the alignment is out and it needs some dash bulbs.
    Mate has been busy though and he's already got a front mount on it.
    Life begins at 140mph
    www.passionford.com
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    1. Use Vagcom to check whether it's the instrument cluster or the crank speed sensor.
    2. Use a better hose clip!
    Mo power, mo problems
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    the rad hoses use a plastic fitting with a wire retainer, either the wire is missing, or your not pushing it on far enough to lock the wire into the groove on the rad.
    Speedo drive is on the gearbox, near/above the nearside driveshaft flange.
    TD5 Land Rover Defender build
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,086
    Cheers, water hose sorted, small drop of silicone lube and the hose went on far enough. Bit too much crud on the ting so the locking wire wasn't going into it's proper position.
    Speedo drive must have got damaged when we did the engine swap.
    Sounds really sweet and healthy though
    www.passionford.com
