Chris NottMonster Motorsport
Results 1 to 11 of 11
Thread: alarm problem
    Feb 2011
    Gillingham. Kent
    10
    alarm problem
    Hi guys,
    I have a problem that is driving me and my neighbours mad. The alarm on my A4 keeps going off, Ive checked that all doors are shut, bonnet and boot also shut tight. But no matter what I do, the damn thing keeps going off. I think thhat the problem may be with the internal sensor that is located behind the drivers seat in the upright. Ive looked at manual and all it can advise me is how to turn it off every time you lock the car, can this be switched off perminantly?
    Please help before I get my car towed by the police.
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    you will probaly find its the internal battery thats knackered, when they start to fail it keeps triggering the alarm
    only fix is to disconnect the siren in the boot, and either fix it, by rigging up a battery pack etc, as replacement batteries arent available since they were only made by one comapny that went bust adn thats if the circuit board hasnt been eaten by the acid out of the battery
    or replace the whole siren, aroun 90 from dealer but can get of ebay for much less also a6 siren fits, arragon will point you in right direction as to which ones do if you ask him
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,014
    Any one near you with VCDS?
    That will tell you what is setting the alarm off.
    As 205man said, disconnect the siren and then set about fixing it.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    As above, vagcom scan to see whats going on.
    Its quite likely the backup battery as mentioned, but if not could be a dodgy door switch or similar.
    TD5 Land Rover Defender build
    Feb 2011
    Gillingham. Kent
    10
    thanks guys, will look to disconnect it temp and replace.
    TDIPOWARRR
    Jul 2010
    618
    Check to see if the bonnet sensor pin is snapped, mine was and kept setting my alarm off. I just disconnected the wires from it and its stopped now.
    Feb 2011
    Gillingham. Kent
    10
    Update on this. I have checked the bonnet sensor, it appears to be ok, but a bit loose in body work. I have cleaned it up and secured it better, but Im having problems finding the horn that is located in the boot. I have taken both covers from each side of the car, the drivers side has the central locking system, the passenger side has a sealed box with Nokia written on it and nothing else. Is it located in the box? Any help would be appriciated. Thanks. I am driving an A4 Avant if that makes any difference
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    Lift up rear seat and you'll find control unit for interior sensors, try unplugging that
    Pre facelift horn is located in left cubbyhole hole behind speaker box, you cAn get to it by removing cd changer cage
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    "Stick a V8 in it!"
    15,381
    and if its a facelift, its on the right hand side of the boot, down low below the level of the floor in the boot.
    Feb 2011
    Gillingham. Kent
    10
    latest update. found the horn and disconnected, only problem was the battery on the car drained. here is a pic of the horn, a complete and utter pain to locates. looked on here for info, all I can find is details on how to replace the battery pack, cant find anything like this in my car. Im driving a 98 plate A4 Avant. Need soem help here. Thanks
    "Stick a V8 in it!"
    15,381
    Ok thats an early horn, and doesnt have a backup battery.
    You need vagcom to see whats triggering the alarm.
