EM TuningJMB Retrofits
Results 1 to 9 of 9
Thread: vag-com scan
    MILTON KEYNES
    11
    Re: Laugh at Ourselves - First Cars...
    Come on Johnny Boy, let's see some pics of your Manta [img]/ubbthreads/images/graemlins/smile2.gif[/img]
    Oct 2003
    #1 - 1956 MG Magnette - co-owned with a mate. Cost 40, sold for 35.
    #2 - 1963 Mini - lower ball-joint came apart 1st day.
    #3 - 1963 Triumph Vitesse. Wedgwood Blue & Black "duo-tone". Loved it. Only car I've ever spun!
    & many more since....such as diesel Chrysler Grand Voyager, FIAT 128 coupe, Rover 827, Golf GTI (for 1 week), Datsun Bluebird, Austin Maxi, Renault 12 (totalled by my mum!), 205 GTi 1.9, 540i Touring etc etc
    Apr 2003
    7
    [ QUOTE ]
    [ QUOTE ]
    Renault 4 van J reg (at the end of number not the beginning) - lime green, matt black bonnet (ran out of paint on resapray) tiny steering wheel... cost 170 in 1973
    [/ QUOTE ]
    oh please tell me you have a photo of that [img]/ubbthreads/images/graemlins/smile2.gif[/img]
    [/ QUOTE ]
    I wish i did ... [img]/ubbthreads/images/graemlins/cry.gif[/img] I am always happy to admit to not always owning a fast car and appreciating what i have even more having started at the bottom!!
    Nov 2004
    England, UK
    63
    vag-com scan
    Hi all, hope u can help me with this.
    I did a scan on my Audi A4 1.8SE 1995 and got the following codes:
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Address 01 -------------------------------------------------------
    Controller: 8D0 907 557 C
    Component: 1,8L R4/5V MOTR HS D05
    Coding: 04001
    Shop #: WSC 00000
    3 Faults Found:
    16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
    P0134 - 35-10 - - - Intermittent
    17734 - Knock-Control: Cylinder 2: Regulation Limit Exceeded
    P1326 - 35-10 - - - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent
    Readiness: N/A
    Address 03 -------------------------------------------------------
    Controller: 4D0 907 379 D
    Component: ABS BOSCH 5 7402
    Coding: 0265108005
    Shop #: BB 37402
    No fault code found.
    Address 08 -------------------------------------------------------
    Controller: 8D0 820 043 D
    Component: A4-KLIMAVOLLAUTOMAT_D63
    Coding: 00041
    Shop #: WSC 06317
    1 Fault Found:
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    30-00 - Open or Short to B+
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 8D0 919 035 D
    Component: B5_KOMBIINSTRUMENT D03
    Coding: 00442
    Shop #: WSC 22531
    Address 25 -------------------------------------------------------
    Controller: 4A0 953 234
    Component: IMMO AUZ9Z0S1251052 D76
    Coding: 00000
    Shop #: WSC 00000
    1 Fault Found:
    01176 - Key
    07-10 - Signal to Low - Intermittent
    End -------------------------------------------------------
    Now what does all this mean? is the oxygen sensor faulty and could this be the cause of my car's rev fluctuating when slow or idle -failed to start on first attempt a few times. Also, I got the flap positioning motor for the climate control fixed a few months back - could that still be there from before the fixed it?
    does any1 know what this all means? help pls.
    Muzz [img]/ubbthreads/images/graemlins/groovy.gif[/img]
    Jan 2004
    York
    1,657
    Re: vag-com scan
    Well the failing to start first few times will be down to the "17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent" fault i reckon.
    Also check the cable going to the lambada sensor, it may have come off if your getting a "no activity" error, or it could be knackered.
    Nov 2003
    Orem, Utah, USA
    144
    Re: vag-com scan
    Yeah, they're the same thing. Never replaced one though, so I don't know about pricing.
    Nov 2004
    England, UK
    63
    Re: vag-com scan
    hey, just out of curiousity-
    I normally leave my climate ctrl on at 22 degrees and press auto. However i notice that the air tends to come out of the demisters/defrosters and the footwells, and hardly any coming from straight ahead. It only comes out from straight ahead when i do the settings manually? should the car be doing this automatically? coz for some reason i got a feeling this may be the problem - the motor is working but not automatically. how would i cure this?
    Muzz
    Nov 2004
    England, UK
    63
    Re: vag-com scan
    ur right, they charge a bomb to fit the motor!! coz its a hell of a job to get to. in total the climate control repair cost me 450. That was for a second hand climate control unit, a full heater box with all motors (only needed one), and labour for 4.5 hours i think.
    Any ideas y i still get the fault code then?
    hop2407's Avatar
    Oct 2004
    Derbyshire
    1,408
    Re: vag-com scan
    No.... Sorry Muzz, No idea why you still get the fault code.
