AH FabricationsEM Tuning
Results 1 to 7 of 7
    Feb 2011
    23
    My leaking issue is back
    Firstly chaps, i have a 96 Audi A4 tdi.
    I had an issue with water leaking into the passenger footwell and setting the alarm off. I had the front panel across the windscreen off and had a check around the pollen filter. I cleaned out a few blocked gutters and this seemed to solve the problem, but we've had some rain tonight and it appears to be back, but its leaking from a slightly different spot. I've taken some photos to show people.
    This is where the water is leaking into the car:
    So its not coming down the bulk head, its more near the front wing/passenger door joint.
    I've had a look under the bonnet and when i pure water down the windscreen there is a starter stream of water down here that heads under the battery, but i dont think this is the source of the leak as the water disappears off somewhere:
    I had a dig around in the front wing near the windscreen and i could a gap down the back of the front wing. Could water be getting into this gap and running down where shown in the first photo:
    Any help appreciated guys as i could do without the alarm waking up the whole street at 2am every time it rains
    Jun 2003
    World of my own
    9,813
    Have you cleared out the drain hole underneath the battery (and also the one further along behind the servo)?
    This is the biggest cause of leaks into the footwell. The drain holes use a rubber grommet supposedly to direct the water away from the boddywork, but they are essentially the perfect design to get blocked incredibly easily and are best removed or at least the flanges cut shorter.
    I had 5 litres of water under the carpets and in the foam, dried the whole thing out (took a day), unplugged the drain holes and 12 months later the same thing happened. When I investigated the drains this time they were literally blocked with a fine sandlike substance, no leaves or debris, so I removed the grommets and never had an issue since. These are the culprits:
    This is the drain with grommer removed:
    Alex Turner
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    Your missing the rain catcher thats supposed to sit on top of the pollen filter by the looks of it. The water will just be pissing thru the filter into the heater blower then leaking out into the footwell.
    TD5 Land Rover Defender build
    Feb 2011
    23
    Thanks for that fella. i'll get the battery off tomorrow and have a gander. Seems an odd place for the water to leak though, i would imagine it to run down the back of the bulkhead if it gathers there rather than where it is. I'll have a gander though
    Jun 2003
    World of my own
    9,813
    I think he's taken that out when he removed the scuttle
    Alex Turner
    Feb 2011
    23
    Yeah sorry, the rain gutter has been removed prior to the photo.
    "Stick a V8 in it!"
    15,385
    Well the filter looks like its been getting wet to me, hence the query. The gutter slots in to two catches on the sides of the filter housing, and if its not in properly you'll get water running down onto and thru the filter.
