Chris NottSky Insurance
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    1.8T Main Bearings - Oddity?
    So i'm slowly getting the parts together to build up the motor on the Shed.
    I've got amongst other things a set of Glyco main bearings, which have me slightly puzzled in that there are 6 bearings with a slot and a hole, and four bearings which are just plain.
    ETKA suggests i should have 5 of each type, with the holed ones going in the block, and the plain ones in the caps.
    At first i thaught it was a packing error, but google seems to have lots of other people with the same issue, and a vauge suggestion that its intentional and that #4 main should have both holed bearings...
    Can anyone confirm this?
    TD5 Land Rover Defender build
    Nov 2010
    52
    They can come either way and is normal. The extra bearing with the hole/slot goes in the center, so between cylinders 2 and 3.
    "Stick a V8 in it!"
    14,900
    Hmm thats different to what the Audi manual suggests, it says the extra hole/slot goes on main bearing 4, nearest the oil pump?
    Nov 2010
    52
    Odd. What I put is the info I got from the guys at IE.
    "Stick a V8 in it!"
    14,900
    Yeh,
    ETKA is strange.
    If i look up a 2000 AJL model, it shows all 5 bearings have a grooved upper and plain lower section.
    If i look up a 1998 AEB model however, it shows one bearing set for 1-3 and 5, and another set for 4.
    The set for 4 has two grooved shells.
    No idea why bearing 4 (or 3 as you've suggested) would actually need a groove in the cap though :/
