Badger5AH Fabrications
Thread: skc code help
    Aug 2009
    191
    skc code help
    I'm trying to get a s4 cluster working in my tqs, it has analouge clock facelift type, the s4 cluster is also facelift with the analouge clock, so should be compatible.
    The only info I can get from the s4 cluster using vagtacho is a 4 digit pin and a identification number?:
    9682
    AUZ7Z0A1795912
    Vagcom want's a 7 didgit skc code and a workshop code, importer number and date the code was created to log in and code the keys etc? How do I find that out?
    any help appreciated cheers!
    2002 A4 AVANT 2.5 TDI QUATTRO
    Aug 2009
    191
    ok just worked it out!
    loged in with 09682 engine now running with s4 clocks dis is very clear, clocks are brand new!
    AUDI S4 1999 INSTRUMENT CLUSTER CLOCKS - 8D0 919 930 PX on eBay (end time 01-Apr-11 14:41:10 BST)
    the x in the part number just means they are an exchange item
