Chris NottMonster Motorsport
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    Found engine code (1Z) on the sticker in the boot, where on the engine is it too?
    My car has had a refurb gearbox, and was told before I bought it that it was a 110bhp, the 1Z sticker says its 66KW so its a 90bhp, Im wondering now if it had an engine swap too, so where on the engine block is the engine code so I can be sure, Ive insured it as a 110 :/ not a 90!
    J
    1996 A4 B5
    1.9TDI SE
    Gone but not forgotten
    Audi A4 2.5TDI Quattro
    Skoda Octavia 1.9SDI (Wont be missed lol)
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,288
    On my 058 block its on a milled flat, just below the cylinder head mating face, on the passenger side of the engine.
    Its very hard to read, and buried under the inlet manifold on a petrol, but might be easier on a derv as its inlet is on the other side.
    TD5 Land Rover Defender build
    flat out
    north weald essex
    220
    on my petrol its at the front of the cam cover but under the plastic over cover
    2001 1.8T B5 Black A4 Avant Votex kit and Ecru Leather
    Jul 2007
    London
    3,209
    Quote Originally Posted by jonnycraig View Post
    J
    Post a picture of the engine bay, if the turbo sits low in the engine bay close to the chassys leg then it's 110Bhp, if it is high on the engine close to the airbox (this will have a metal deflector plate bolted on the side by the turbo) then its a 90 Bhp. The gearbox code is at the back of the engine block on a straigh milled surface but as mentioned above, it will be hard to read...
    FOR SALE:
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    Thanks, its definately a 90bhp
    1996 A4 B5
    1.9TDI SE
