Volks AutosChris Nott
    Feb 2011
    Suffolk
    10
    Drone, Drone, Drone?
    Hello all.
    Would I be right in saying a drone round a left hand corner is the driver side bearing? It goes quiet round right handers.
    Also, how easy is it to get the sump off? (1.8 20v n/a) The chain tensioners making unholy row! I want to give it a flush, clear out the oil pick up and replace the leaking sump gasket. Makes sense to do it all at once.
    I know its full of orange plastic bits from the dipstick guide that fell to pieces!
    jcb
    Sep 2005
    uk
    4,070
    sounds like you have a lot to do!!
    bearing noise can be transferred so what sounds left is actually right. but change in tone on cornering is usually a safe bet
    you will need to lift the car/engine up off the subframe slightly to clear the sump
