Sky InsuranceChris Nott
Results 1 to 14 of 14
    Feb 2011
    Suffolk
    10
    What will happen if I disconnect my battery?
    Bit of a silly question I know, but what will happen?
    I've just got the car and dont have a radio code or anything. Bit worried about the throttle body re-adapting correctly. Should I be concerned about anything else?
    Aug 2009
    191
    you will have to put code in for the radio, think you can disable the code with vagcom before disconecting battery. Nothing else to worry about.
    2002 A4 AVANT 2.5 TDI QUATTRO
    Feb 2011
    Suffolk
    10
    Thanks.
    I have Vagcom lite, can I do it through that?
    Sorry, also forgot to say its a 98 1.8 n/a 20v, if that makes a difference.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,472
    it wont start ?
    Feb 2011
    Suffolk
    10
    Yeah, ok. Left myself open for that one!!
    bez101's Avatar
    Jul 2008
    8,472
    if you have remote keys you will have to match them back to work
    your 1 touch windows will need resetting
    radio maybe maybe not
    clock date etc resetting
    think thats about it
    why do u need to disconnect battery
    Feb 2011
    Suffolk
    10
    How do I re-match the keys (actually only have one) and the windows?
    I just want to make sure the drain holes underneath it are clear.
    bez101's Avatar
    Jul 2008
    8,472
    for the windows you press and hold down till open and still hold for a few secs
    then the same close them keep hold for a few secs
    if you have remoce central locking put key in ignition turn on press lock unlock
    turn off shut door lock with button
    bez101's Avatar
    Jul 2008
    8,472
    quick way to check look if no puddle of water should be ok
    or pour bucket of water in and watch under car if it drains its ok
    Aug 2009
    191
    can't find the radio coding options now, may have been a different radio! will keep looking.......
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    Ive had my battery off a few times and the only thing I had to do after was reset the one touch windows.
    Radio just said LEARN then started working, remote fobs were fine etc.
    TD5 Land Rover Defender build
    "Stick a V8 in it!"
    15,350
    Feb 2011
    Suffolk
    10
    All done. No probs at all, radio just came on as normal, didnt actually try windows, remote fine and throttle body made a squealing sound for about 10secs.
    Drain hole blocked solid, tray full of water! I thought hole was a grommet for a second.
    Thanks to everyone for their input!
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,395
    "What will happen if I disconnect my battery?"
    The World will end....
    IT COULD ALWAYS BE WORSE SO KEEP ON SMILING
