Volks AutosBadger5
Results 1 to 12 of 12
    Jul 2008
    Birmingham
    629
    Clutch shopping list
    Can someone give me a list of things I need to buy to replace the clutch on my 1.8T AJL quattro? Preferably with part numbers! Obviously I need a clutch - but what else? It's not really my area of expertise...
    A4 1.8TQS
    Feb 2008
    If you go on the Euro car parts website and enter your reg it will list all parts needed.
    I have recently upgraded my A4 clutch to a larger 240mm S4 clutch and a custom lightweight flywheel from TTV Racing..,which is also an option if your looking at increasing the power/performance of the car?
    hope that's of some help
    cheers
    Jul 2008
    Birmingham
    629
    Thanks mate. I've just realised my question is slightly retarded. :P
    If I was to change to an uprated clutch and SMF, what are my options. I heard an Audi 80 TDi SMF will fit with some clutch and should be good for decent amounts of torque. Any details? Also how would they compare, in cost and performance, to this kit:
    Valeo Audi | Euro Car Parts UK
    Cheers.
    P.S. I'm insuring my car next weekend so I can get it through its MOT and get the clutch sorted out, so I can sell it. Life is good lolz.
    A4 1.8TQS
    May 2010
    Bedford
    2,877
    Only problem with the valeo kit is you can only use that valeo clutch on the flywheel. Nothing else.
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,287
    Dont sell it, drive it!!
    I fitted a 1Z flywheel and clutch to my old 1.8T, and it seems to handle the power of a remapped engine alright, although to be fair it never gets driven hard, so cant really say how long it would last or hold up to getting a hard life.
    If your looking for a cheap and cheerful fix to enable you to punt it on, then fine.
    A slightly better option is to use the same 1Z flywheel, and have it redrilled to accept a S2 (3B engine) clutch, which is 240mm. cost a bit more for the machining, but likely to be much better suited to handling whatever you can throw at it.
    TD5 Land Rover Defender build
    Jul 2008
    Birmingham
    629
    A4 1.8TQS
    May 2010
    Bedford
    2,877
    And slip as soon as it hits a sniff of boost lol
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    Ive just got a kit from ebay for my 1.9tdi. only paid 40, new, Sachs friction plate and pressure plate inc new release bearing:D
    Jul 2008
    Birmingham
    629
    Bargain!
    Can someone confirm if AEB and AJL use the same clutch? I heard AEB et al is 228mm whereas AJL is 230mm? Is this true?
    A4 1.8TQS
    "Stick a V8 in it!"
    15,287
    The AJL IS an AEB.
    The engines are completely identical in every way.
    The different code simply signifies that the AJL is 180hp.
    So they both use the same 228mm clutch.
    Jul 2008
    Birmingham
    629
    So then it also uses the same clutch as the non-turbo? Lame. No wonder they don't last.
    A4 1.8TQS
    Nov 2010
    52
    If your looking for a A4 1.8t clutch
    228mm, 240mm and even a 8.5" super single kit for the A4 1.8t.
