Volks AutosEM Tuning
    Feb 2011
    Key fob question
    Having just swapped the casing on my damaged fob that was Glued together but the previous owner (its a 1999.5 A4 avant TDi), in doing so, i have broken off one of the SMD Resistors / Capacitors
    It's located on the battery terminal side of the circuit board (see attached image)
    Can anyone pop thir key apart and give me a number off theirs so i can aquire and solder a replacement on?
    the key fob is the usual B5 3button flipkey
    And i wondered why it wasnt working but guess it was my own fault for using a knife...
    Cheers guys :D
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    Can anyone help with this. 2sec job (as if you were changing battery) and its visible need to get remote unlocking working as i currently unlock the drivers door and put key in ignition to open the other doors and boot and when loading the car its a right pain...
    Ross_S4
    Aug 2009
    Dundee
    718
    Board in mine is different and no resistor there. sorry mate.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    mine reads 103
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Arrkon's Avatar
    Oct 2010
    1,641
    cheers guys, all sorted.
