Volks AutosEM Tuning
    Sep 2009
    Gloucestershire
    54
    Airbag warning light on
    Started the car up as normal thursday morning and the red circular airbag warning light (which normally goes out on ignition), has remained on since.
    Anyone know why this happens, or most likely culprit, or how to turn it off? Have 98 1.8T with bags in steering and seats
    /sprint_48 / Audi b5 A4 1.8T //// // //
    Badly Parked Dubs
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,390
    quite likely the under seat airbag connectors
    TD5 Land Rover Defender build
    Sep 2009
    Gloucestershire
    54
    Good shout. Will check them tomorrow in the light
    Badly Parked Dubs
    griswold's Avatar
    341
    you will need to use vag com or a handheld scanner to clear the error
    i bought a airbag reset tool off ebay because vag co couldnt clear the airbg ecu memory fault and the handheld did clear it
    so its handy to keep in glove box about 20 quid on ebay
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
    Sep 2009
    Gloucestershire
    54
    So if there's a loose connection and I fix it tomorrow, the light will stay on until I clear it? If so, won't be able to tell if fixed (if it's not blatent to the eye) Or will it just stay on the fault memory?
    Badly Parked Dubs
    griswold's Avatar
    341
    yep you need to scan it to find out what code it is
    and clear it
    it wont go just by cleaning the seat connections
    it could be something else not the seat wiring
    A6 2.4 Avant SE
