Badger5Monster Motorsport
Results 1 to 9 of 9
    Izzy1's Avatar
    Vorsprung Durch Technik
    Sep 2008
    Birmingham, UK
    348
    STOCK TURBO RECON!
    Hi Guys,
    looking for some guidence. My Turbo vanes are sticking and i'm looking to take the turbo out, clean it all up and put it back in. Having never done this before and being a novice i look to you guys for help and inspiration.
    Do I need any special tools?
    I've had a look at some guide for a 1.8T removal and on there the guys disconnected oil and other fluid lines. do i need to do the same?
    mine is a stock TDI one.
    any help and guidence is highly appreciated.
    also if anyone has a write up on how to do this would be great.
    Izzy
    Bora TDI sport
    Audi A4 TDI
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,973
    There is the oil feed pipe at the top and the drain pipe at the bottom.
    That will need to removed along with the exhaust pipe and air pipe.
    I dont know much more than that.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    I was hopingg not to drain any fluids...
    Having a look on Evilscotsmans threat on sticky vanes it appears a few guys have had some success with the "Mr Muscle" process. I think i'll give that a shot as i don't want to start draining oil and other fluids.
    will attempt it on the weekend.
    Izzy
    Bora TDI sport
    Audi A4 TDI
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    Quote Originally Posted by Izzy1 View Post
    Hi Guys,
    How do you know this?
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    3rd,4th,5th gears above 4RPM when the car is under load will throw it into limp mode.
    oh and i've been told by my local VAG specialist...
    Izzy
    Bora TDI sport
    Audi A4 TDI
    PaulTheo's Avatar
    Aug 2010
    Bristol UK
    126
    Have you fully checked for the simple items first such as vacuum leaks or boost leaks? And you will not need to drain the sump to remove the turbo but if you are woried about doing that you might not want to try the manifold bolts and exhaust bolts.
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    weekend gone i took the EGR and mani off my Bora and gave that a good clean. should be putting it back on tonight and will see if that's made a diff on performance as it was lacking a little through the gears...
    don't think i have the confidence or space to do a turbo strip as i live on a main road.
    Izzy
    Bora TDI sport
    Audi A4 TDI
    flying oyster's Avatar
    flying oyster
    Jul 2009
    wimbledon
    547
    mine was lacking in power as well on my tdi stripped egr gave a clean hey presto runs great like new car
    S3 8L ming blue westys old car shed loads of mods
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    i''ll be cleaning that out along with the mani on the weekend.
    Izzy
    Bora TDI sport
    Audi A4 TDI
