Results 1 to 18 of 18
    Dec 2010
    Inverness
    38
    Audi A4 TDI Starting issues
    Hey All
    My Car – Audi A4 Avant TDI 1998
    Its had new glow plugs
    I am down to sorting the last problem on the Audi J
    Right when I go to start it in the morning I need to warm the glow plugs a good 5 times this seems to be because the “glow plug light” literally comes on for a second then flicks off so I assume the plugs are not getting a good heat to start.
    The garage checked the car out and said all the glow plugs are fine. They are unsure on what to do?
    I need to heat them a good 5 times to get the car to start.
    Car runs perfect and will start first time when its warm.
    Any ideas?
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    Sounds like air might be getting into the fuel lines during the night causing it to be more difficult to start, used to happen to my fathers car so he used to park it point down hill over night, it worked until he got it fixed turned out to be the fuel line connectors to the pump.
    Hope this helps
    JC
    1996 A4 B5
    1.9TDI SE
    Gone but not forgotten
    Audi A4 2.5TDI Quattro
    Skoda Octavia 1.9SDI (Wont be missed lol)
    Dec 2010
    Inverness
    38
    Unfortunatley I stay in in the flattest area lol so no joy for that.
    Is there any way to check that?
    Also would that effect the glow plug light just flicking off as on my old Ibiza TDI it used to stay on a few seconds weather depending and all that.
    Today its minus 1 and it just flicked off within a second lol
    Dec 2010
    Inverness
    38
    Also my mate just emailed me this having a pop at what he thinks it is
    Potentially defective engine coolant temperature sensor.
    The management system uses a signal from this sensor to determine whether your plugs need to be pre-heated or not. On warm days or when your engine is already hot the management system either heats the plugs for a very short time or doesn't pre-heat them at all."
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,423
    CTS can cause the problem you have
    worth a try easy to fit and not much cost
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    Similarly see if anyone around has VAGCOM to get the codes off and see if it picks up anything.
    1996 A4 B5
    1.9TDI SE
    Dec 2010
    Inverness
    38
    Would this one do it
    AUDI TEMP TEMPERATURE SENSOR GREEN 4 PIN A2 A3 A4 A6 A8 on eBay (end time 15-Feb-11 23:33:35 GMT)
    Also where is this located in the engine bay?
    Can i download VAG COM to my laptop as I have OBD2 cable.
    bez101's Avatar
    Jul 2008
    8,423
    im not sure if the will fit your car last 1 i got for a diesel was black
    your better off geting OEM from audi or gsf
    around 20 quid
    you can download a free version off vcds but to be honest its crap
    only does limited things
    Dec 2010
    Inverness
    38
    Will check the colour of mine tonight when Im done at work but this looks promising. Its pissing me off lol
    I will try find a cracked version of it hopefully :-)
    Thanks lads
    Any other ideas?
    Aug 2010
    1,540
    what engine code is it? temp sensors in the plastic coolant housing on the back end of the head.
    Jul 2007
    London
    3,211
    I would also check the timing for the injector pump, if too advanced/retarded you will also experience hard starts...
    FOR SALE:
    Dec 2010
    Inverness
    38
    Sorry where about is the cooling sensor?
    Whats strange is today the light stayed on and the car started no problem but yesterday it took 5 times lol
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,304
    follow the top radiator hose back towards the engine, and you should find the sensor. Its a 4 pin square plug probably located behind the cylinder head.
    Before doing any of that though, why dont you actually diagnose the problem...
    Get the car hooked up to vagcom and view the coolant temperature, and see if there are any coolant sensor related fault codes.
    1997 S4 - PPC ÂŁ999 Challenge Track Car Build
    TD5 Land Rover Defender build
    Dec 2010
    Inverness
    38
    I have Vagcom but it wont load up.
    I have installed it and using my OBD2 cable connecting it to the car but it just doesnt find it. Gives an error about my OBD2 port been invalid and there is no config file.
    I have another program which I lets me connect the car but its showing no error codes as the EM light is not on.
    "Stick a V8 in it!"
    15,304
    Your car doesnt have OBD2.
    A random cable wont work, you need a lead designed for vagcom. They're on ebay for about a tenner.
    Dec 2010
    Inverness
    38
    My car does have an OBD2 port as i managed to run another diagnostic cable on the car to check some sensors.
    Could you send me a link to the cable bud?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,967
    Quote Originally Posted by Connor_scotland View Post
    It has the standard port but uses a different signal protocols to communicate with the equipment on the car.
    Go to ebay and search for VAG-COM or VCDS.
    I would get the link for you but i can't use Ebay in work.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    15,304
    I didnt say you car didnt have an OBD2 Port, i said it doesnt have OBD2!
    As Axios says, it uses its own VAG protocol for the diagnostics, not the standardised OBD2 protocols.
    My lead looks something like this: VAG COM USB DIAGNOSTIC CABLE 409.1 OBD2 II LEAD VAG-COM on eBay (end time 22-Feb-11 13:00:32 GMT)
