JMB RetrofitsEM Tuning
Results 1 to 14 of 14
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Rear brakes and wheel bearings.
    Next month I'm replacing my rear disks, pads and wheel bearings.
    With all this off and being replaced is there any thing else worth looking at, replacing or just generally cleaning and maintaining?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    flat out
    north weald essex
    220
    sheilds, cables, shoes and rear bushes??
    2001 1.8T B5 Black A4 Avant Votex kit and Ecru Leather
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Quote Originally Posted by nwmlarge View Post
    I'll inspect them but not fitting new bushes just yet.
    shoes, On disks? or am i thinking of thing else?
    Cable. Hand brake cable? It seems fine at the moment. I'll double check it.
    Shields, Not a bad idea at all. If they are solid, i'll give em a clean and a paint.
    flat out
    north weald essex
    220
    is it not shoes inside the rear discs ?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    Nope, the caliper itself has a handbrake mechanism on it.
    Not really much else to do on a FWD, its quite a basic setup.
    Give the bushes a good pry to check for movement. They almost certainly will be knackered.
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    I'll have a look.
    I hate doing bushes.
    Thanks.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Izzy1's Avatar
    Vorsprung Durch Technik
    Sep 2008
    Birmingham, UK
    348
    is this for pre-face lift models or if that's the process in general for rear disc replacement? (removal of the bearing)?
    Izzy
    Bora TDI sport
    Audi A4 TDI
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Quote Originally Posted by Izzy1 View Post
    I'm doing mine on a pre-facelift.
    I assume its the same for all FWD models.
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    do you need a special tool to press the bearings in with?
    Izzy
    Bora TDI sport
    Audi A4 TDI
    tux
    tux's Avatar
    May 2010
    Notts/Derbys Border
    89
    Looks like taper bearings so just a hammer and suitable drift to drive out the races. A suitably sized socket is needed to put the races back in.
    If it can't be fixed with a hammer, then it must be an electrical problem
    "Stick a V8 in it!"
    15,388
    I tend to use a screwdriver and a hammer!
    A useful trick though, is to knock the old races out (with the screwdriver and hammer) then take a grinder and cut a slot in both of the old races. Then you can sit the old race on top of the new one and beat it with a hammer. Might need to stack two of them up to get it all the way home. Once done, the old race just lifts out due to the slit.
    tux
    tux's Avatar
    May 2010
    Notts/Derbys Border
    89
    Now that is a TOP idea!
    foursprungdugtechnique's Avatar
    Jan 2011
    Perth, Scotland PH1 2BN
    279
    I did mine a while back, new discs, pads, bearings and the ABS rotors were all done. Handbrake cable is fine, so it can stay. Next on my list is the rear bushes, All of them and I have one broken spring, about 1" of the plastic coated bit came off, but they are 10 years old (as far as I know), so no point in messing about when the rear is stripped anyway.
