Monster MotorsportBadger5
    nemo2182's Avatar
    Lord wont u buy me a V10 R8!
    Oct 2005
    uk
    110
    Lightbulb S4 Xenon Question
    Ive recently realised how poorly adjusted my xenons are. Considering they are meant to be considerable better than standard Halos, mine only seem to pitch about 10ft from the bonnet . Now I think they need adjusting, but after a little surfing, seems that lowering the car messes the system up?? I dropped mine 50mm a good year or so ago, and havent noticed mine auto adjusting (moving up and down) since, so think mine r playing up. Now, I also know there are some manual adjusters on the lights that can change the horizontal and vertical pitch. Is this easy enough to do?? or are there some other 'tricks' I can do to make these better??
    2000 B5 S4 - MRC Remap - RS2 Sparks - Pipercross Element (dried) + Modified Airbox - Forge Divs - Samco Hose's - KW's dropped 50mm - 18" RONAL R41 in gun metal grey - Black Diamond Combi Disc's + Predator Pads - Brushed Alloy Mirrors - Short Shifter - Full Recaro - Carbon Trim - Bose. More to come, watch this space.......
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,291
    You need to check the xenon control unit for faults first off.
    You can manually realign them, but you need vagcom to put the control unit into setting mode before you do so.
    TD5 Land Rover Defender build
    nemo2182's Avatar
    Oct 2005
    uk
    110
    Hello mate, i can always rely on you to respond......
    Do I need full Vag com, or can I do it through the unactivated version. i.e. I havent paid 100 to ativate it.
    "Stick a V8 in it!"
    15,291
    Not sure to be honest. You can certainly read the codes with your standard version.
    HerefordQuattro's Avatar
    Hereford
    303
    unfortunately the lite version doesn't allow for xenon setup only the code reading
    A6 Avant 2.5tdi Quattro Sport 220bhp 458Nm 6 speed Manual
    132
    The xenon lights have a yaw sensor for adjustment of the light angle. So lowering would have some effect on it.
