Sky InsuranceAH Fabrications
Results 1 to 11 of 11
    flat out
    north weald essex
    220
    b5 fwd rear bushes
    i have been looking through the site and have been unable to find any decent info on this.
    Am i looking in the wrong place?
    i want to replace the rear bushes on my 2001 fwd 1.8t avant.
    i was hoping to find a guide detailling if it is indeed possible as a home job with a bush puller ?
    2001 1.8T B5 Black A4 Avant Votex kit and Ecru Leather
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,353
    i did mine with marks help with some bits of threaded rod and random bits of tube.
    Got the new bushes from AllGermanParts.
    TD5 Land Rover Defender build
    flat out
    north weald essex
    220
    i'll have a look on there.
    was it simply a case of dropping the beam and pulling them out ?
    do you have to unclip any brake lines etc ?
    did you need to use heat?
    "Stick a V8 in it!"
    15,353
    No heat.
    I supported the beam on a jack, unbolted the bushes and lowered it down carefully. I didnt remove any brakelines, but you can only JUST get enough space to lower it before the flexis bind up, so care is required.
    To get them out you need a tube thats a close fit to the bush casing on one side and one thats bigger than the bush outer on the other, then use an assortment of bits of plate, washers, nuts and some threaded rod to draw the bush out.
    flat out
    north weald essex
    220
    sounds like a reasonably sensible procedure.
    as they are sleeved i expect they come out reasonably easily ?
    pjw
    Nov 2010
    Helensburgh
    203
    Use a blowtorch and burn the rubber out.
    Then hacksaw the sleeve and pop it out.
    Keep the new one in the freezer the night before and it slides right in.
    Bosh.
    Paul
    Purpur A4 B5 - -50mm - S4 Interior - RS6 Alloys - 3" Stainless Exhaust - K&N Intake - HID
    "Stick a V8 in it!"
    15,353
    Blowtorches and flames under the car near the brake pipes and plastic fuel tank....
    Your a braver man than I.
    flat out
    north weald essex
    220
    Quote Originally Posted by pjw View Post
    Bosh.
    is this experience of an audi ?
    pjw
    Nov 2010
    Helensburgh
    203
    Yeah, and to be honest most trailing arm bushes too.
    If your not comfortable with burning just use a screwdriver to carve the rubber out, then twist it and rip it to bits with a spanner.
    See here:
    Suspension Audi A4 rear suspension bush replacement - VZi, Europe's largest VW, community and sales
    Awesome walkthrough.
    Paul
    flat out
    north weald essex
    220
    that is a good walkthrough!
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    That's a good guide!
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
