JMB RetrofitsVolks Autos
Results 1 to 16 of 16
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    Leaking turbo pipe
    I noticed some smoke coming out from under my bonnet today.
    I opened it up and noticed it was coming from a leaking pipe on top of the turbo.
    This is a older pic of the leaking pipe.
    Its leaking between the nut and the pipe.
    I'm tempted to just take a spanner to it but wondering if there is a washer or seal that could do with replacing.
    Any one got any hints or tips for doing this?
    A4 1.9 110 TDI 1998 AFN engine.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    TDIPOWARRR
    Jul 2010
    618
    It's the oil feed pipe for the turbo, someones probally had it off before and not tightened it properly.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,288
    yeh its just a compression fitting, try and tweak it up.
    I think you need to replace the line to that actuator as well!
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    I ordered a new union bolt thingy, that they said fits between the pipe and the turbo. I'll collect it next week if tightening it up does not work.
    Yeah, thats been on my list of things to do. That and another pipe or two.
    Will any rubber pipe do?
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,055
    Any rubber/silicone pipe will do dude
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    That nut is not moving.
    I tried tighten and nothing.
    I cleaned all the oil off to make sure that is where its coming from and it comes out of there rather fast.
    I'll have to wait till the part turns up next week before I sort this out.
    its leaking from top of the nut. I hope its the union and not the pipe it self.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    Fixed the oil feed pipe leak today.
    It was the pipe at fault, the sealing ring at the end of the pipe was coming away from the pipe, letting oil through. I replaced the hole lot, all bolts, seals and pipe.
    Some pics.
    The old leaking part.
    New union bolt joint thing.
    New pipe
    flat out
    north weald essex
    220
    was the pipe off the shelf?
    2001 1.8T B5 Black A4 Avant Votex kit and Ecru Leather
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    Quote Originally Posted by nwmlarge View Post
    Delivery.
    I got the union from VW and the pipe from Audi. lol
    3 times i went to a VAG garage and I never picked up any new pipe work for the thingy on top the turbo.
    Jul 2011
    do you not find it is coming from the bottom of the turbo also? i have tightened my bolt up a bit and it stopped from the top but is still coming from the bottom.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    Quote Originally Posted by netdef View Post
    Not seen any thing from the bottom pipe, only from the top.
    Jul 2011
    21
    Hi Scott,
    you don't happen to have the part number for the union thingy do you?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,961
    Quote Originally Posted by chud View Post
    Hi Scott,
    I don't sorry.
    Any good VAG dealer should beable to tell you.
    Feb 2012
    I think first you tight the pipe as you can do it and after that it still leaking so you can use the rubber pieces and tight it surrounds the pipe, and as I can think the problem will be solved.
    ___________________________
    Leak Detection Specialist
    Sam
    Oct 2011
    Bomber County
    37
    The bottom pipe may be the same but you wouldn't notice as the oil isn't burning off the turbo as it drips on. I use braided oil lines on my mk2 golf, partly because its not standard and partly because they are shiney and look nice. A good hydraulic pipe shop (one in most industrial areas of the town) will make you one up for little money.
    Arrkon's Avatar
    Midlands regional Moderator
    Oct 2010
    Coventry, West Midlands
    1,641
    Hi Scott,
    I think it would be:
    028145786
    Currently rolling in a SKODA!!!
