EM TuningAH Fabrications
Results 1 to 23 of 23
Thread: AC Strip
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    AC Strip
    I'm bored and thought it be a good idea to strip down my AC control unit and give it a clean.
    You will need a T6 screw driver to take the unit apart.
    First get a set of AC Controls
    Remove the two screws that holds the fan in place. The fan can be a bit stiff to pull out but give it a wiggle and a tug, it will soon come out.
    Then the 4 screws that hold the faceplate to the body. Left and right of the fan is two clips. small screw driver or the T6 screw driver, in the top one and little wiggle away will release. Do the same for the other side.
    When remove the faceplate what out for the ribbon cable. This is soldered on to the button board.
    Lay the faceplate down and you will see 4 more T6 screws. Remove theses.
    You should now be left with just the buttons.
    Time to take the buttons out and give them a clean. If you look on each side of a button, you will see a small hole. This is the catch that stops the buttons from fall out. You will need to push the button out, towards the front past this clip. Just go careful not to stab your self, break the button or damage the tracks (this will make the buttons movement rough). Use a small screw driver and gently push down with in the hole on each side. I used cotton wool buds and some alcohol cleaner.
    Below is a picture of the springs. one of the plastic welds was snapped off and caused the metal spring to move away from the panel a little. I used my soldering iron and melted some more plastic over it. It seemed to hold during the test and refitting of the buttons.
    Time to clean the fan. Unless this has been done before the fan will have about 10 years of hair, skin and other particles.
    Screw driver, cleaning alcohol and cotton wool buds did the job.
    I also removed the boards. No real reason, just felt like it.
    And put it all back together.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    Have you retrofitted a facelift console?
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Almost, slowly building up the parts.
    Got air vents, Hazard switch, switch panel, AC panel and Ash tray.
    "Stick a V8 in it!"
    15,372
    Surely its easier to get the lot from one car?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Yup.
    If I can find a car with the same colour dash as mine and double din then I would have bought the complete dash.
    Theses parts was available when I collected my rear electric windows.
    "Stick a V8 in it!"
    15,372
    double din consoles are extremely rare, if you had a chance of one already, you should have taken it. Its far easier swapping out the common bits of dash trim than trying to find a beige console!
    Is the ashtray you have from a double din console?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Single din.
    I would have bought it if it was double din and not bothered about the colour.
    My interior is slate grey with wood trim or what ever its called.
    Came from a single din unit.
    "Stick a V8 in it!"
    15,372
    It wont fit the double din console then, single din ashtray is a different shape! Same with the climate unit, it sits further down on a Double Din car and is shaped differently to fit.
    Docurley had a complete double din console a while back, i was going to buy it from him, and then he misplaced it. Last time i spoke to him he'd found it again though.
    Any particular reason your wanting to go double din?
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    That i was not awear of.
    I thought the only difference was the cage and faceplate. every thing else was the same but fitted in different locations.
    Worth a PM?
    At first I liked the idea of having an RNS unit fitted at some point, thought about getting bits for a double din to fit a symphony untill I got an RNS unit.
    Not 100% sure what i want in there. Not thought about it much over the last couple of weeks.
    I guess my final decition will be made by what parts are avaliable and how impatient i am.
    "Stick a V8 in it!"
    15,372
    Nah the front of the climate forms the edges of the fascia panel on double din, rather than being square with a surround round it as on single din, in effect there is no faceplace on the double din console:
    As you can see, the ashtray is also mounted lower down, and is hence narrower and more tapered to fit in the smaller gap.
    Yeh i'd fire him a PM.
    I might have the ashtray off you as the one in the shed is busted, but i'll need to pull it out and see whats wrong with it first.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Ahhh I see.
    PM sent.
    I'll get this week out of the way and i'll take a look and see whats out there. If i got no use for the ash tray i'll let you know.
    Thanks for the info.
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    Axios good pics, i left a drink from McD's sitting in the cup holder for a week yuk i know, and what happened was it slowly seeped out the bottom of the cup and went down the buttons on the LH side of my climate control buttons they are now sticky i did try and clean them out with water and old tootbrush, this did help however they are still a bit sticky...
    how did you take the buttons out? do they come out from the rear thus de-soldering the plastic spot welds? ideally i dont want to mess with those
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    "Stick a V8 in it!"
    15,372
    I think they just pop out from his description.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Quote Originally Posted by rasA4 View Post
    They pop out from the front. No need to touch any of the metal on the back. I did to fix something that was broken.
    Pushing on the back of the buttons or using a small screw driver pushing down on the little clips on the side will work.
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    Quote Originally Posted by Axios View Post
    Ok sweet will have to take it out again
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Feck me, you must be bored....Feel free to come do mine if you have any more bored spells mate! Lol
    Thats some muck thats came from the fan, never really thought of that before, now you've got me thinkin, hmm.....
    Project RS28 build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Quote Originally Posted by Foxmeister View Post
    Post it down and i'll do it.
    jonnycraig's Avatar
    Jun 2009
    Port Talbot
    158
    Time to prob sound like a complete noob but whats the little fan do?
    1996 A4 B5
    1.9TDI SE
    Gone but not forgotten
    Audi A4 2.5TDI Quattro
    Skoda Octavia 1.9SDI (Wont be missed lol)
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Quote Originally Posted by jonnycraig View Post
    Sucks air in from the cabin past the temp sensor.
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Would you? How much?
    Quite able myself, but i know i'd never get round to it, im a c&t at doing these type of things! Ha
    Project RS28 build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Cover postage for both ways and some beer token.
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Good stuff mate, will do. Cars in bodyshop now so should be back in a wk or 2, will sort it out when i get it back then, cheers!
    Project RS28 build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    I'm not sure if I should start a new thread or not but here I go.
    I've stripped and cleaned two of theses now and both are loads better than when I got them.
    I'm using one but the other is either going to go on ebay or if people wants, I'm more than will to take your Current AC unit and give you the one I cleaned for some beer tokens.
    I'm also tempted to do the same with the Pre-Facelift AC unit.
    Let me know.
