EM TuningSky Insurance
Results 1 to 30 of 30
    '98 A4 2.4 SE
    Apr 2007
    Nr. Sheffield, UK
    99
    Control Arm Replacement?
    Hi all
    Just a couple of questions about replacing B5 A4 control arms...
    I'm sick of having to keep replacing arms periodically, so am thinking of biting the bullet and doing them all at the same time.
    I've found a complete set on eBay from a seller in Germany (cartech-one-1)... Has anyone used these before that could vouch for their quality? Also does this kit come with absolutely every bit needed to perform the transplant? If there's a better option (other than OEM from Audi), I'm all ears!
    How long should a competent garage take to swap them all over (excluding allignment)?
    Many thanks in advance...
    Josh
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Theres only two makes i'd touch, Meyle or Lemforder.
    Buy ****e from ebay and you'll be changing them all again in 6 months time. Been there done that.
    Meyle kits are available on german ebay which contain a full hardware kit with new nuts and bolts, these are the only ones i'd be looking at.
    TD5 Land Rover Defender build
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    Had a couple of QH arms in the past. Might as well have been chocolate for the time they lasted. Only use Lemforder or Meyle now.
    Life begins at 140mph
    www.passionford.com
    '98 A4 2.4 SE
    Apr 2007
    Nr. Sheffield, UK
    99
    Ahh OK thanks for the info. Quite a jump in price!
    Am I right in thinking the main difference is the quality of the bushes, or am I barking up the wrong tree?
    Josh
    Jan 2004
    York
    1,641
    Everything is better, the metal forgings, bushes, bolts etc.
    8V S3 Sportback with options on order
    '98 A4 2.4 SE
    Apr 2007
    Nr. Sheffield, UK
    99
    Ok, will start saving my pennies for a Meyle kit then!
    Thanks guys.
    Any idea on how many hours labour it'll require?
    Josh
    "Stick a V8 in it!"
    14,900
    It took me a day, on the drive with a fairly comprehensive (but not to garage standard) tool set.
    The upper pinch bolts are known for siezing, and if this happens it makes the job quite a pain in the arse. One of mine was siezed solid, and needed drilled out in the end. Was probably a good couple of hours messing with that one bolt.
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    I used a febi bilstein set on mine and all ok so far after 10k miles.
    Feb 2009
    228
    does anybody have any reviews of the ecp kit? I was speaking to the local branch and was told they do a full set for 250
    "Stick a V8 in it!"
    14,900
    I'd be wanting to know the make of the parts.
    phoenixv6quattro's Avatar
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    If you end up getting a kit from meyle ask for the S4 TRE's instead of the standard ones that come with the kit.
    !!BINGO BONGO!!
    flat out
    north weald essex
    220
    are the s4 ones longer lasting ? i'm on my second set in a year
    2001 1.8T B5 Black A4 Avant Votex kit and Ecru Leather
    "Stick a V8 in it!"
    14,900
    If you buy decent quality parts they'll last the same 10 years that the original ones did.
    A4 rod ends have a rubber isolator in the middle of them, which damps vibrations but reduces steering feel.
    S4 ones dont, and are just solid metal.
    flat out
    north weald essex
    220
    is that good or bad? for general driving like
    "Stick a V8 in it!"
    14,900
    It improves feel, which is why they were fitted to the S4 and TQS models as standard.
    flat out
    north weald essex
    220
    they'll be on my list of upgrades then. worst case i can always swap them back!
    flat out
    north weald essex
    220
    i just looked on ecp for the s4 ends and can't seem to see which are the solid ones.
    "Stick a V8 in it!"
    14,900
    Allgermanparts can get you them, i baught Lemforder ones, were about 35 each.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    Cool, am replacing my TRE's on the 27th Jan Will order some S4 ones now rather than the stock ones
    www.passionford.com
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    Just checked on ECP and they only list one TRE for both the 1.8 and the S4?
    www.passionford.com
    "Stick a V8 in it!"
    14,900
    Well they're wrong :P
    They probably dont stock the S4 ones at all.
    Give allgerman a call.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    Will do mate, cheers
    www.passionford.com
    Jun 2003
    World of my own
    9,813
    I bought the cheap german ebay set and they lasted 3 months, groaning all the way. Don't know how the guy has the gaul to sell such crap. Total waste of money. It took me 2 days first time round (pinch bolt was a real pig on passenger side), 6 hours when I'd saved enough for the Meyle kit from allgermanparts. This set have been on a year now and 20k miles, not a squeak out of them. The tech write up on audiworld is a godsend.
    Alex Turner
    staylowmovefast
    Sep 2009
    wycombe
    1,391
    Agreed
    !!BINGO BONGO!!
    flat out
    north weald essex
    220
    "Stick a V8 in it!"
    14,900
    They're advertised as Febi arms.
    Ian above says he used Febi and they were fine.
    Personally i've never used them, but baught a couple of Febi tie rods for the rear suspension and one of them had a huge casting defect which had clearly made it all the way thru their quality control and onto my doorstep. In the end i sent them back and ordered Meyle ones instead.
    They're certainly going to be better than the chinese junk thats for certain.
  28. #27
    flat out
    north weald essex
    220
    fair enough.
    not what i'd call a glowing review so far lol
  29. #28
    132
    Can anyone reccoment a german supplier of Meyle HD control arm kits ? Maybe one off german ebay ?
  30. #29
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,065
    i wouldnt recommend the febi arms
    replaced mine about 3 years ago on my avant and needed to replace 2 arms for last years mot
    the car now feels very sloppy
    by contrast my tqs is on original arms (cars covered 70k) and had its first arm failure this years mot and advise note the year before about drop links used lemforder to replace both as i figure 11 years 70k is a fair amount of time for them to last
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
  31. #30
    Jun 2003
    World of my own
    9,813
    You can get them from the crook that sells the cheapo ones on german ebay (autoteile or something), but I refused to give him any more of my money and bought them from allgerman
    Alex Turner
