Sky InsuranceVolks Autos
Results 1 to 9 of 9
Thread: relay layout
    pjw
    Nov 2010
    Helensburgh
    203
    relay layout
    how can i find out what relay is for what under the drivers knee? ive got the service manual and all it shows is how to remove the whole relay unit :s
    Paul
    Purpur A4 B5 - -50mm - S4 Interior - RS6 Alloys - 3" Stainless Exhaust - K&N Intake - HID
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,909
    The relays are all numbered, so it shouldnt be too hard to look up the relay number and find out what its for?
    There cant be too many relays under there i wouldnt have thaught?
    TD5 Land Rover Defender build
    pjw
    Nov 2010
    Helensburgh
    203
    i dont know.. im looking for J106
    Paul
    "Stick a V8 in it!"
    14,909
    As i told you before, the ABS relays are all inside the ABS pump/ECU.
    pjw
    Nov 2010
    Helensburgh
    203
    OK, i just wanted to confirm. Ill give up and go with it!
    Is the module under the rear seat or is it the one on the side of the pump?
    Paul
    "Stick a V8 in it!"
    14,909
    As far as i'm aware the ABS ECU is bolted to the side of the pump itself.
    You can probably remove it and have it repaired by someone like BBA_Reman
    The only thing under the rear seat on mine is the control unit for the interior monitoring system
    pjw
    Nov 2010
    Helensburgh
    203
    So is there a difference between tha ABS controller and the ABS ECU? I only ask as theres two different types of unit on ebay, the big 100 bits and theres 25 electrical boxes. If its a relay would i be able to get away with just swapping this small unit?
    This is what im on about:
    Audi A4 ABS Ecu 1996 4D0907379D on eBay (end time 31-Jan-11 11:51:22 GMT)
    Paul
    "Stick a V8 in it!"
    14,909
    Maybe the earlier cars are different?
    The later ones dont have a box like that, the electronics are all on the side of the pump itself.
    For 25 i'd try changing that ECU pictured if your car has one!
    pjw
    Nov 2010
    Helensburgh
    203
    Im going to have a look at whats on mine.. But theyre on ebay for next to nothing. If thats where the relay is then its worth a shot?
    Paul
